Pcb design ,Good morning someone does pcb work, I want to do a budget to draw a pre
  • Pcb design ,Good morning someone does pcb work, I want to do a budget to draw a pre
    Good morning someone does pcb work, I want to do a budget to draw a pre bass,
    Do you have a schematic or do you need someone to design the circuit AND the PCB?
      hello Nickb
      have schematic
      copy pre ampeg svt 6 pro
        Itīs a very complex job, so nobody at a Forum will design that for you.
        A PCB Factory will, but then they will expect you to order, say,fom 100 to 1000 PCBs.
        They will want to make the effort worthwhile, so they will evenly split the PCB design cost between delivered PCBs.
        Meaning you will end up with 1000 excellent price PCBs or 100 expensive ones.
        Not such a thing as a free lunch
        For "just one" or a few, number$$$ simply donīt add up.
        Meteoro copied some Gallien Krueger Bass amps, but then they made hundreds or thousands of them.
          ^^^^What Juan said. The cost would run into the thousands of US$ for something like that.
            Much cheaper to buy an SVT6, discard the power amp and transformer, then build it into a new enclosure with a smaller power supply.
              Yes. You might even be able to find a cheap broken one on eBay.
                Excellent idea. Most serious faults would leave the preamp unscathed - shorted output devices, bad transformer or PSU maybe.
