Hello,
I'm a proud owner of a Fulltone Tube Tape Echo (TTE) but have a little hum issue.
I got the TTE in the U.S. but brought it back France.
Since I already have a couple amps running on 110V, the TTE is running on the same 750W grounded step-down transformer, which measured output is 119V / 50hz.
Neither amp hums without the TTE, but with it the Fender Super Reverb amp has some hum and the Deluxe has more, enough to be bothersome.
Could a small DC voltage on the power circuit cause the TTE toroidal transformer to produce some hum?
Another related note - there is a semi-loud <crash> noise when I switch pickups on my strat, like a capacitor discharging. Very annoying and sounds like something is really wrong. This never happened before using the TTE, and does not occur when I don't use the TTE.
So... I measured the DC voltage on the TTE input line (with no output connected), at 0.5V. I could be wrong but I believe that's high.
I also measured the DC voltage at the 220V receptacle at 0.05V.
Is it possible this DC voltage is being carried through and maybe amplified to 0.5V on the input?
The real question - is it this DC voltage causing the amps to hum and the strat to make noise between moving the pickups?
If so, I was thinking of cleaning up the power by building this DC filter (http://sjostromaudio.com/joomla/inde...d=62&Itemid=27) to place before the 750W step-down transformer. Would that cure it? (Or am I way off.)
The TTE is running on 120V, but I could change it (per the manual) to 240V. But I'm not sure that would help, and the change (in theory) should not really be needed since I should have good voltage (119V) already.
I have tried other receptacles in the apartment, but so far the TTE causes hum no matter where I plug it in. Moving it away from the amps or around in the room makes no difference. I may bring the whole setup to my office to test there. I've also tried several guitar cables - no difference. Cables are not long. I don't have an oscilloscope.
I've also written Fulltone but thought I'd ask here too.
Thanks for your help and advice,
Paul
Paul
