Originally posted by Sowhat
View Post
I've got an "adustable temperature" Weller station that you adjust by changing tips. The available tip temperatures are 600F, 700F, and 800F, the "standard" being 700F. I may not be lightning quick, but my dwell time for pot terminals is under a second. I've used the standard tip for boatloads of 24mm pots... no problem. Pickup coil wires... no problem. Through-hole PCBs... no problem. Bournes 16mm pots with push-pull switch... big problem.
Just sayin'.
-rb
