I have an AVT50 tValvestate 2000 that blows the main 4 amp fuse only when either of the power amp CB (CN1) is plugged into it...I started off by marking all the connections carefully, uplugging everything from the power amp boards and the "mother" board, then began from the Xfmr, and began plugging connections in one at a time then turning the power switch on. Everything was fine until I plugged in the CN1 connector that goes to one of the power amp boards (the board mounted to the heat sink, cooled by fans)...then the fuse blew. I replaced the fuse, unplugged the first Power amp board, plugged in the second power amp board...and it blew a fuse again. I measure +48V -48V and 0 V across pins 1,2 and 3 respectively...is this correct? I also poked around the "mother" board and found an unusual reading from the 7915 (- 15v reg chip)...it measured 80 ohms across the pins 2 and 3 (in both +/- directions) ...measured across the 22uf Cap right next to it and read 80 ohms again (in both +/- directions). The cap is designated C123 but I can't find it in the schematic. I little nervous now about installing new TDA7293's because I don't want to blow them up again if something else is causing them to blow (12 bucks a pop!...and I mean "POP"!)...any suggestions? Thanks!
P.S.: Enzo...thanks again for the schematic!!!
