Mesa Mark V feature list
  • Mesa Mark V feature list
    http://forum.grailtone.com/viewtopic...1000&start=150
    MARK V™ 40th ANNIVERSARY
    Simul-Class™ Power Amp (Patents 4,532,476 & 4,593,251) featuring Multi-Watt™ (Patent Pending) and Duo-Class™ (Patent 7,173,488) technologies which provide three power and three operating class options that are channel assignable via 10/45/90 Watt Power Switches: Choose 2 power tubes operating in pure vintage Class A (single-ended), producing 10 Watts - 2 tubes running in time-honored Class A/B producing 45 Watts or 4 tubes running in Mesa’s legendary, patented Simul-Class Power that blends the best of Class A and Class A/B simultaneously to produce 90 Watts of pure tonal magic / 4x6L6 (or 4xEL-34), 7x12AX7, 1x5U4 • Bias Select Switch (6L6/EL34) • Fixed Bias for Consistent, Maintenance Free Performance • Full Power/Variac Power™ Switch (Patent 5,091,700) • 3 Fully Independent Channels with 9 Modes (Channel 1 = Clean, Fat or Tweed™, Channel 2 = Edge, Crunch or Mark I™, Channel 3 = Mark IIC+™, Mark IV™ or Extreme) • Normal/Bold Switch on Channel 1, Normal/Thick Switch on Channel 2 (Mark I mode only), Normal/Bright Switch & Pentode/Triode Switch on Channel 3 • Each Channel features: Independent Gain, Treble, Mid, Bass, Presence, Master, Footswitchable or Auto-Assignable Contour Depth Control, Footswitchable All-Tube, Long Spring Reverb Control, Rectifier Tracking™ (Auto-selects Tube for all 10 Watt Modes, Diode for all 90 Watt Modes, selectable Tube or Diode for 45 Watt Modes on Channels 1 and 2, Diode for 45 Watt Mode on Channel 3 - Patents 5,168,438 & 7,193,458) • 5 Band Graphic EQ is Footswitchable, Channel Assignable and Selectable between 1 group of 5-Band Sliders or 3 channel specific, variable depth Contour Controls • Footswitchable, Channel Assignable or True Bypassable All-Tube FX Loop with Send Level Control (over all channels when activated) • Output Level Control (over all channels when activated) • Footswitchable Solo Level Control – Patent 6,724,897 (over all channels when activated) • True "Hard" Bypass Switch removes FX Loops, Output Level & Solo Level Controls from signal path • Tuner Output w/Footswitchable Mute • Slave Out w/Level Control • Fan Cooled with On/Off Switch • External Switching Jacks for Channels 2, 3 (channel 1 is default), EQ & Solo • Aluminum Chassis • New 4x4 - 8 Button Footswitch (Bottom Row: Channel 1, Channel 2, Channel 3, Solo – Top Row: Reverb, FX Loop, EQ & Tuner Mute) • Slip Cover • Kitchen Sink, Ice Maker, Beer Cooler (just kidding) but easier to use then this list suggests (not kidding)!
    Model # Description Pro Net
    2.MVM.BB Medium Head (Width 22 7 /8 ").............................................1999. 00
    1.MV1.BB.CO 1x12 Combo • C90 Speaker • Casters........................................2099.00
    ELECTRA™ Simul-Class™ 45/90
    Simul-Class™ Power Amp (Patents 4,532,476 & 4,593,251) featuring a 45/90 Watt Power Switch that incorporates concept elements from our Patent Pending Multi-Watt™ and Patented Duo-Class™ technologies providing two power and two operating class options: Choose 2 power tubes operating in time-honored Class A/B producing 45 Watts or 4 tubes running in Mesa’s legendary, Patented Simul-Class Power that blends the best of Class A and Class A/B simultaneously to produce 90 Watts of pure tonal magic / 4x6L6 (or 4xEL-34), 7x12AX7 • Bias Select Switch (6L6 / EL34) • Fixed Bias for Consistent, Maintenance Free Performance • Single Channel simplicity with the performance versatility of a Multi-Channel amp through 3 Footswitchable Modes (Classic Boogie Clean, Vintage Low Gain, Vintage Hi Gain) • Channel Control Features: Volume (Gain), Treble, Mid, Bass, Presence & Master Volume • All-Tube, Long Spring Reverb with Auto Reverb Defeat Switch for Vintage Hi & Lo Modes (Defeat Mode removes Reverb from Vintage Hi & Low Modes but retains Reverb on Clean Mode – Normal Mode applies Reverb to all Modes) • Reverb Hard-Bypass Switch removes entire Reverb Circuit from amp • FX Loop w/Automatic Hard-Bypass to completely remove when not in use • Slave Out w/Level Control • External Switching Jacks for Vintage Low/Hi (Clean is default) & Reverb • 17" Aluminum Chassis (rack-mountable option available) • 2 Button Footswitch (Classic Clean, Vintage Low/Hi) • Slip Cover
    TBA Head (Width TBA) ........................................................ .1599.00
    TBA Rackmount Head ........................................................ ...1599.00
    TBA 1x12 Combo (Width TBA) • Speaker TBA• Casters.............................1699.00
    TBA 2x12 Combo (Width 26 ¾") • Speakers TBA• Casters..........................1799.00
    M9™ BASS AMPLIFIER
    900 Watts @ 4 or 2 Ohms (450 @ , Trans-Class™ Power with 8/4 or 2 Ohm Impedance Switch for optimum Power to Load Performance / 10 Power MOSFET’s, 1x12AX7 • Active/Passive Input Switch • Vacuum Tube Preamplifier featuring: Gain, Active Bass w/Pull Deep, Passive Mids, 5-Position Active Mid-Voicing Switch, Active Treble and Master Volume w/Pull Mute • Footswitchable, Assignable or Bypassable 9-Band Graphic EQ with Mid-Voice Active/Defeat Switch (Voice Active Mode combines 9-Band Graphic EQ with Selected 5-Position Active Mid-Voicing Switch EQ, Voice Defeat Mode defeats the Selected 5-Position Active Mid-Voicing Switch EQ to "Flat" when 9-Band Graphic EQ is selected, allowing you to footswitch between your favorite Active Mid-Voice setting and 9-Band EQ Curve independently of one another • Assignable or Bypassable Compressor with Independent Threshold and Ratio Controls • Tuner Output w/Footswitchable Amplifier Mute • FX Loop w/Automatic Hard-Bypass to completely remove when not in use • Balanced XLR Line Out with Pre/Post Switch & Ground Lift • 2 – Combination Speakon -1/4" Speaker Output Jacks • Fan Cooled • 2 Button Footswitch (EQ & Mute)
    6.FM9 M9 Carbine Rackmount Bass Amp • 2 Rack Spaces.............................1199.00
    2.FM9.AA M9 Carbine Head • Black Bronco Vinyl • Slip Cover.........................1349.00
    MESA® 1X12 WIDEBODY, CLOSED BACK, FRONT PORTED GUITAR CABINET
    TBA 1x12 WideBody Closed Back • Front Ported • 90 Watt • C90 Speaker • 8 Ohm...469.00
    RACKMOUNT HEADS
    In addition to the products listed above, Rackmount versions of the following amplifiers will be available for the same price as a head.
    Express 5:25
    Lonestar
    Lonestar Special
    *** The new price lists also indicate that the Stiletto Ace is available in a Rackmount Version, unfortunately it will not be (due to chassis size) ***
    http://www.mesaboogie.com/
    Rivera S120, Marshall JMP-1, EL34 dual monobloc
