Can someone please tell me how to see if a power amp is operating in Class A push-pull? I modded my 5E3X2. The plate voltages are at 300v and there is roughly 32ma on each 6V6.
Measuring Output Class
Originally posted by lowell View PostCan someone please tell me how to see if a power amp is operating in Class A push-pull? I modded my 5E3X2. The plate voltages are at 300v and there is roughly 32ma on each 6V6.
Hope this helps
Best regards
BobHoc unum scio: me nihil scire.
Assuming you have good 6V6s in there, if the 6V6s are cathode-biased, you can set them at 46mA per tube if you are only running 300V on the plates. Cathode biasing provides automatic adjustment to bias - depending on plate voltage (as the plate voltage increases the voltage drop across the cathode resistor also increases, which increases the bias) so it is perfectly safe. I think they will sound better at 46mA per tubeLast edited by tubeswell; 01-18-2009, 12:17 AM.Building a better world (one tube amp at a time)
Class A = 100% plate dissipation at idle.
Class B = 50% plate dissipation at idle.
Class AB = between 51%-99% plate dissipation at idle.Last edited by Old Tele man; 01-17-2009, 06:58 PM....and the Devil said: "...yes, but it's a DRY heat!"
Class B 50% at idle? I thought class B each tube was biased right at cutoff. Only conducts on its own half of the cycle.
COnducts 50% of the waveform in class B, while class A conducts 100% of the waveform. That isn't dissipation though.
Class AB conducts 51-99% of the waveform.Education is what you're left with after you have forgotten what you have learned.
Guys I appreciate the response. However I know what Class A is and am familiar w/ biasing etc... I'd simply like to know how to measure if it IS in class A or not. Can someone tell me how to do this? I was using a scope yesterday and saw that the amp is still NOT in class A as there is a scoop on top of the voltage waveform for each side of the OT. Which I guess answers my question of how to see if it is in Class A or not. So now I'm curious as to how I get rid of this scoop. I'm guessing it's something to do w/ the PI...?
Originally posted by lowell View PostETR,
Interesting... would you mind enlightening me on why?
This argument is only valid if the tubes were perfectly linear. In practice, the presence of even harmonic distortion causes the B+ current draw to increase with drive, and the cathode voltage to rise accordingly, even in Class-A.
RDH4 calls this "rectification" and says that it can be significant with beam tetrode tubes.
I guess it would be easy enough to tell the difference between the gradual current increase caused by rectification, and the sudden rise that would happen as you came out of Class-A."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Originally posted by Steve Conner View PostThis argument is only valid if the tubes were perfectly linear. In practice, the presence of even harmonic distortion causes the B+ current draw to increase with drive, and the cathode voltage to rise accordingly, even in Class-A.
Good info guys and thanks. So constant current/voltage drop across Rk is result of Class A operation. So how much change in current/voltage drop across Rk is to be expected when deciding operation is no longer in Class A? Are we talking couple ma?
