I'm wondering if someone can explain what a "B" taper is. I'm just curious because I'm finding it difficult to find pots with that particular taper. An even better question is whether another taper would suffice (like audio for example).
Potentiometer Taper explanation
Depends on what side of the pond you're on:
http://www.generalguitargadgets.com/...=174&Itemid=44
In the US, B means linear taper.
In Europe, B means audio taper.-Mike
in america, and a is audio and that means you have a smooth volume curve from quiet to loud and visa versa. B stands for linear which, when applied in audio applications gives you an uneven change, some guitars have these linear pots for volume dials.
However, i've read older american pots labeled B for audio, and A for linear so if its real old, it can be the other way around.
point is, each one will suffice and have the same full on and full off but the sweep in between will be different.
Originally posted by Darquilver View PostAn even better question is whether another taper would suffice (like audio for example).
Log (audio) pots make good vol pots (the relationship between volume and power is a logarithmic one, and log pots reflect vol proportionately)
Linear pots make good mixing pots and are often used as presence pots or reverb level control pots
Tremolo speed pots are antilog (reverse audio) pots
As one of the other posters pointed out - the nomenclature can vary. If you're not sure, measure the pot at different parts of its rotation
You can custom taper the pot in question by adding a resistor from wiper to ground (log taper) or adding a resistor from input to wiper (antilog taper). E.g.; an off the shelf 'two-line' log taper pot can be further log-tapered (i.e. bulgier curve) by adding a resistor from wiper to ground (although this will decrease the pot's overall resistance as a voltage divider)Building a better world (one tube amp at a time)
