Page 1 of 4 1234 LastLast
Results 1 to 35 of 108
Thread: Does cap voltage affect tone?
    Old Timer daz's Avatar
    Jan 2007
    2,567
    Received: 1/0
    assuming you are safely over whatever the cap needs to handle in it's context, are there any places in an amp where using say a 450v cap instead of a 50v would affect tone in any way? I seem to notice something but it's too subtle to count placebo effect out.
    Aug 2006
    Lancashire
    645
    Usually no, but with some electrolytics, when operating under very low polarising voltages or very low signal voltages, low frequency distortion can occur.
    Jan 2007
    2,567
    Received: 1/0
    You mean if the caps are rated pretty high?
    268
    Ceramic caps can change pretty dramatically in capacitance depending on the voltage across them. Their rated capacitance is usually given at some percentage of their rated voltage. At their rated voltage their capacitance can be tens of percent less. I'm being vague because I'm too lazy to look up the numbers. Can this be audible? I dunno. A lot of people think so. Personally, I tend to be skeptical of such things but this is the one capacitor/tone thing I find most plausible.
    Jan 2007
    2,567
    Received: 1/0
    Thats not what i meant. What i was asking is say you have a cap on a preamp cathode and in place of a small 10v 1uf cap you put a 450v 1 uf cap. Will the big 450v cap that can handle about 400 times as much voltage as necassary in that context cause any change in tone over using that 1uf 10v cap?
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,199
    Received: 173/0
    Given: 241/0
    Not if all other things are created equal. And they never are. A high voltage cap will have differences in construction (spacings, etc.) from a lower voltage cap. Since electrolytics are said to have poor performance at higher frequencies I would think this only gets worse with an increase in dielectric spacing. Not really sure about that and it may not even apply to audio frequencies. But the point is that differences in construction can cause a difference in performance. But I doubt the difference would be any greater than changing from one low voltage cap to a different brand of low voltage cap. I'm pretty picky and I don't think I would hear the difference in this application. That isn't to say you can't. It's just to say the difference is really really small. And to further eliminate this difference you could take two totally different 10uf electrolytics and bridge each one of them with a 1uf film cap. This would probably eliminate any performance difference between the two. It's a neat trick to improve performance on electrolytics. But again, the difference is so tiny in this application that you will wonder if your imagining it. So I don't bother.
    What merlinb said is also true. But I've never noticed a problem using 100v caps for preamp bypass so I've never reconed with it.
    Something you may want to try is dry tantalum caps. Alot of guys here will poo them for their supposed high failure rate. But they may be talking about the cheap little blob looking ones that you almost never see anymore. I use the little plastic cone headed ones made by Kemet. I've abused them pretty badly with some circuit errors. Even had two installed in reverse polarity recently. The crazy thing is, not only did they not fail, they were working. I tested them and then reinstalled them correctly (re-reversing the polarity) and they still didn't fail. I've used them in a dozen projects without incident. They have much better audio performance than electrolytics. You will hear a difference. And they will last many times longer. I only use them for preamp cathode bypass circuits. I took the idea from Mesa who has been and is still using them.
    Chuck
    Aug 2006
    Lancashire
    645
    Quote Originally Posted by daz View Post
    Yes. In a very low-voltage situation, a high-voltage cap is liable to give low frequency distortion. This only happens at very low polarising voltage though, or large signals voltages (I got that back-to-front in my earlier post). So if you used a 450V cap for a cathode bypass, you could expect some ugly bass.
    See 'Capacitor Distortion' p175
    http://books.google.co.uk/books?id=B...amps#PPA175,M1
    Mar 2007
    Philadelphia suburbs
    491
    Chuck, I'm with you on the dry tantalums. I use them all the time in cathode bypass applications. In many cases I find that they give me the best tone, at least the tone I am looking for. Less constrained without being irritating like poly bypass caps can sometimes be. I don't use them in all circuits but I always give them a shot and find they work very nicely a lot of the time.
    Mar 2007
    491
    The caps could also have very different ESR. That could account for the tone shift more than just low frequency distortion (not to discount that idea, just adding another one - I'm no expert on caps).
    Jan 2007
    2,567
    Received: 1/0
    Good stuff, thanks all ! I'm going to see if i can find some tants. i may even have some on old boards i save for parts, tho i likely won't be lucky enough to find tha values i need. but this sounds like a good idea.
    Jan 2007
    2,567
    Received: 1/0
    Thanks for the idea on the tantalums. I also heard in the past that regular caps in place of electro's is a better way to go. So i didn't have a .68uf tant for the first stage cathode, but i did have a epoxy dipped style .68uf cap and used that, and i have 1uf caps on two other stages and i DID find 1uf tants for those. Long story short it seems to have totally eliminated a certain super high end buzziness i hear when using semi clean tones via the guitar volume knbs. I have always had that isse in most every amp i've had, and it's always bugged me a bit at times. this seems to have eliminated it altogether and the tone just seems purer or something. Good call guys, this is not a real subtle improvement so i say thanks much ! (i mean, not HUGE, but certainly not subtle)
  12. #12
    May 2007
    pacific north west
    13,199
    Received: 173/0
    Given: 241/0
    "Purer" is a good way to describe it (wow, that word looks funny spelled out).
    It just sounds more natural and open. Like the gain stage is doing it's job without fighting the short commings of the componants. The great news is that the Kemet tants that I use are available in most of the common values like 1, 2.2, 10 and 22uf. Interestingly I find myself most often using values that are uncommon. You can also get 3.3, 4.7, 6.8, and 15uf values. I find the 1, 2.2, 3.3 and 15uf values the most useful for my personal amps. But I don't own a Tele or a LP. Idealizing an amp for the guitar you will most often use with it is the ultimate in tweaking.
    Chuck
  13. #13
    Jan 2007
    2,567
    Received: 1/0
    I'll have to see if i can get a .68uf for the first stage. probably won't matter since i now have a epoxy cap there instead of a electro, but what the heck. By the way, do tants NOT come in values under 1uf?
    Good thing i had a 10x eye loupe tho....the + sign on those tants is so small i could never have possibly seen them with anything less. I couldn't even see it thru my lighted magnifier.
  14. #14
    May 2007
    pacific north west
    13,199
    Received: 173/0
    Given: 241/0
    1uf, .68uf, Whats the difference? I wouldn't quibble over .32uf in a cathode bypass circuit. But FWIW most of the Marshalls I've seen use a film cap in for that value and they are redily available.
    The tants I use are chamfered on the + end (kind of semi cone shaped) so it's easy to tell polarity. I can't imagine trying to accuratly read the marks on the little blobs that are most dry tants.
    Chuck
  15. #15
    Jan 2007
    2,567
    Received: 1/0
    Thats what i figured too, but there really is a difference. I didn't notice much till i played it for a while with a 1uf there, but i ended up putting the .68 back in because there is just this slight difference that changes it enough to mater. It may make more difference if your amp is marshall voiced because it seems as tho it does give it a slightly more marshall sort of voice or feel. Subtle, yet not, if you know what i mean. in any case, placebo effect or real, it makes me happy so i have to remain a slave to my ears be they right or wrong.
  16. #16
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,160
    Received: 23/0
    Given: 37/2
    OK Chuck! I wish you were there when I got spanked over Tantalum caps in another thread... Enzo and others greatly dislike them. They have nice low voltages which are perfect for cathode bypass and they are much better than EL in many applications...they do explode sometimes when greatly abused (MnO2 ->O2 + BOOM)
  17. #17
    May 2007
    pacific north west
    13,199
    Received: 173/0
    Given: 241/0
    There is alot to be learned from the (ehem...) more experienced members here. In fact guys like Enzo and Bruce are the biggest part of what makes this forum the best of it's kind. But the idea that tantalums are crappy caps that will always be a problem waiting to happen IS a bit antiquated. Modern tants have very reasonable specs and IME are reliable in the given application. Further, their audio properties are far superior to electros. I don't think I would even consider tants in most applications, but if they ever had a niche, this is it. Consider that Mesa Engineering has been using them for over a decade. The biggest failure issue with those amps is burned PC traces. I've never even heard of a failed bypass cap. But consider that they (and we) are using 15 and 20 or 25 volt caps in 1.5 volts of operation. Still, this seems to make sense if it's giving results. And it is for me.
    Chuck
  18. #18
    Jan 2007
    2,567
    Received: 1/0
    Well, i hate to be the naysayer, and i'm not saying i am doing a 180 here. But i really need to test any changes i do in a live situation. And being that i seldom play out anymore, the way i do it is with a cranked up sound system pounding out tunes of the type i prefer. I did that tonite, and i found that as good as the changes i made seemed, in a mix there were issues for me. Big surprise here....why i don't expect this kind of thing by now i don't know. But sure enough it was not happening. I loved the tone i was getting. But as soon as i played it in a mix it was unusable. I don't know exactly what caused that, but the changes i made were to put tantalums and epoxy caps in 4 places including the first 2 stages, as a gain boost which was a switchable cap on the 2nd stage cathode, and a .68uf cap in the NFB loop. Instead of removing them one by one to see where the issue may be, i reinstalled all the original caps at once. Mainly because i don't have the luxury of cranking the amp for long periods due to the neighbor issue. In any case, when i reinstalled the original caps i was back to what works. the difference was that the tone sort of fit in the mix nicely verses being TOO fat and big to fit in the mix. It was also less rich with harmonics. The only way i can explain it that might make sense is to say the tone was like a sine wave in that there was no harmonic content i could hear when in the mix, and the highs just disappeared. Mind you that it sounded great by itself. But as always when try something new it always is nite and day between how it sounds with the amp by itself and when in a mix.
    So what i think i have to do is take the time and try each cap change one at a time and try to find which caps that will make a positive difference in a mix and which were the ones that were responsible for ruining the tone within a mix. One thing is for sure, and i've dealt with this for years, no change can be evaluated till it is heard within a mix. Playing the amp by itself is so very tricky because what sounds fantastic can easily be and often is just the opposite within a mix. what it comes down to Chuck, is that these caps may well be great, but you have to experiment and find where they work right for you and whether they need a change in value too. All, i can say at this point is that putting everything back to stock i got my usable tone back. But i feel in certain positions they will be an improvement. I just have to take the time to experiment with them and find which positions they do the magic in.
  19. #19
    May 2007
    pacific north west
    13,199
    Received: 173/0
    Given: 241/0
    I couldn't agree more. "In the mix" is the only way to know anything with amp design. I've had some horendous experiences playing out with some of my early mods I originally thought were great.
    But... Consider that your ears get trained to your gear. I recently have been evaluating speakers for an amp I designed and not surprisingly my favorite speaker with this amp is the same speaker I've been playing all my amps through for the last twenty two years. I knew at that point that my brain was playing shinanagins on me. So I asked my wife to do a listening test... She chose the "other" speaker Who knows at this point. I have a vision. But apparently it is narrowed a bit by conditioning. I'm really trying to like the other speakers. But it's just not working out.
    There's a tip in here somewhere.
    Chuck
  20. #20
    Jan 2007
    2,567
    Received: 1/0
    I know what you mean, and it is very very tricky at times. there are times you just cannot understand how you can be hearing what you are hearing when things were so different before, even when you haven't done anything. But even being "trained" to hearing the amps' sound, i just could not adjust the amp to get remotely close to fitting in the mix without being a completely different and uninspiring sound. I will try each one one at a time and see if i can get back some of the good w/o the bad.
  21. #21
    May 2018
    San Diego, CA
    40
    Received: 15/5
    Given: 5/3
    If your using a way bigger voltage rating electrolytic cap....it will behave like a much lower uF cap at lower voltage...
    The plates will pull towards each other at full voltage and "press" the dielectric material to a smaller thickness" thus larger capacitance...
    Depending on the material ....Capacitance vs Voltage Gradient across the dielectric....some cases are more dramatic than others...this is the effect that occurs when a cap re-forms after discharge....
    The affects of caps are barely noticeable at low levels and when viewing normal sin waves in the audio range.... things become more apparent when the amp is cranked and you are making square waves ....the harmonics extend past the audio range at 1/f 1st order roll-off...then roll off at 1/f^2 at some given dominant POLE in the circuit...
    Depending on the Tantalum cap.. many have ESR as high as 10 to 20 OHMS.... this will dampen any ringing in the square waves and make for a smoother guitar sound... In MIL design the Tantalum caps must always have some serious derating...
    I have used this MIL-STD 1547B for a lot of work I did in the past... It is a good guidline to use for Hi-REL design...
    http://everyspec.com/MIL-HDBK/MIL-HD...1547A.2102.pdf
  22. #22
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,186
    Received: 219/3
    Given: 241/4
    Quote Originally Posted by cerrem View Post
    It doesn´t happen to any significant degree.
    If capacityance were voltage dependent, 2 things would happen:
    1) it would create A LOT of distortion, and that effect would be widely known and studied ...it is not.
    2) being a significant parameter, Manufacturers would show this in datasheets, including some curves or graphs ... they do not.
    "Sounds" logical as a piece of conversation but would love to see some data about it ... lots of things "sound logical" but then don´t happen in reality.
    That´s different, and is a sllloooowwww process which takes hours or days, absolutely unrelated to Audio frequencies.
    A cap does not "reform-unreform" many times a second like when Audio is applied.
    You bet.
    Yes on power tubes, and OTs can (and should) have wider bandwidth than raw Guitar signals ... but are played through Guitar speakers which fall like a brick, 24dB/Oct or worse, above 3 or 4 kHz.
    How can they do that if they are on *cathodes* ?
    And to boot usually on Preamps, where gain stages are followed by strong tone shaping or plain HF killing, notice those 100pF to 1000pF caps in parallel with plate resistors in many High Gain amps ... those which are designed to make lots of funny squarewaves.
    http ://everyspec. com/MIL-HDBK/MIL-HDBK-1500-1799/download.php?spec=MIL_HDBK_1547A.2102.pdf]
    Now I see.
    I congratulate you on your wide RF and MIL Electronics Experience and understand you see things through that lens, but in Guitar land things are way slower and easier.
    1 Not allowed! Not allowed!
  23. #23
    Mar 2018
    Germany
    274
    Received: 75/0
    Given: 54/1
    And it would show when measuring uncharged HV electrolytics with an LCR meter. While such measurement may actually show a reduced capacitance value by 20% to 30%, a bias voltage of 5V (meaning that the cap is charged to 5 VDC during C measurement - some LCR meters provide this useful option) typically suffices to bring C (and ESR) up to spec for a good cap.
    So definitely not "like a much lower µF cap".
  24. #24
    May 2018
    San Diego, CA
    40
    Received: 15/5
    Given: 5/3
    You bet.
    Now I see.
    Sounds like you are clueless..... I could explain for 100 pages and you still wont get it... You don't even know what a Network Analyzer is... Look up a HP 3577 and read... It's an ANALOG signal sweep and it sweeps as low as 5 Hz ... not in the RF range... its not DIGITAL it measures impedance ..Been designing and building audio amps guitar amps for 45 years.. Also design capacitors for a major manufacturer....Stay out of my post and stay out of yours...
    -4 Not allowed! Not allowed!
  25. #25
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,129
    Received: 221/1
    OK, we often hear of various phemonena. So answer this:
    a typical 20uf 500v cap as used in a zillion B+ supplies. I will believe you that the capacitance might effectively change with voltage applied, but I have trouble with "much lower" and "much higher". So HOW MUCH does the capacitance change when using a 20uf 500v cap on say 25v?
    I did read through the 300+ page document you linked, but unless I missed something it seemed to focus on tantalums and film caps. I didn't spot plain old vanilla electrolytics.
    I would consider a 10% shift to be within tolerance.
  26. #26
    Supporting Member
    Staffordshire UK
    3,377
    Received: 36/0
    Given: 32/0
    Sounds like you are clueless...Stay out of my post and stay out of yours...
    That's just silly, please don't 'take on'. Please don't act like a 'god on high' and rage if someone should dare to raise a query.
    This is a public forum, for better or worse there's no 'your thread' and 'my thread'.
    Other forums may happily lap stuff up and not be troubled by the paragraphs of missing material represented by each ellipsis.
    The nature of this forum is more akin to 'peer review'; if a technical statement is made, even one by a competent, venerable member, the onus is on them to justify it, provide at least something to verify the point.
    We're not expecting a full report with exhaustive citations etc but there's really no point just writing conclusions without 'showing us your workings', ie give a guideline by which someone similarly resourced and competent could reproduce your finding.
    I respect you and I'm very pleased that you've decided to grace us here with your insights.
    However, the points made in response to your posts contain queries that crossed my, and I'm sure many other reader's, mind.
    A prime example being your remark about tantalum caps and their ESR acting to dampen ringing with square waves; such a statement is frustrating and basically useless without any context, examples etc.
    I acknowledge this may make creating material hard work; an example of how this can be done well may be found http://music-electronics-forum.com/s...ad.php?t=46108
    Ultimately, it leads to a better result, with everyone involved in the thread, including even the OP, perhaps gaining a greater understanding of the topic.
    As such, this forum occasionally exemplifies, in some small way, the real benefit of the www, as by documenting and publishing such new, previously unknown / unpublished or forgotten insights, the sum total of human understanding of our universe has been incremented ever so slightly.
    10 Not allowed! Not allowed!
  27. #27
    May 2007
    pacific north west
    13,199
    Received: 173/0
    Given: 241/0
    Hey cerrem. To put it another way... Glad you're here. Please take it down a notch
    And Happy Birthday.
    5 Not allowed! Not allowed!
    "I'm just going to perform a bit more scientific investigation, turn it up to 11 and rip of the knob." überfuzz
    "If you build it, it will hum..." Justin Thomas
  28. #28
    Oct 2007
    10,186
    Received: 219/3
    Given: 241/4
    Not answering to anybody in particular, just taking a *realistic* look at what can be found on any Guitar Amp related Tech bench.
    And I am not talking only a regular "Service" Tech, who usually is involved in repairing stuff back to original working state but with no need for reengineering, but also including Factory Engineers (think Fender/Peavey/Marshall/Ampeg/Laney/etc.) who do design Production Amplifiers.
    Somewhere I heard an HP3577 being mentioned:
    http://www.testequipmentdepot.com/us...zers/3577a.htm
    Yes, signal output can go as down as 5 Hz ... somebody might want to test a Network performance that low ... considering it touts a 200MHz range I somewhat doubt low frequency measurements are its forte.
    Won´t copypaste what it can do because I would fill the page, just notice that none of its about 100 impressive features includes or even mentions measuring capacitors, it´s focused on Networks, only component they mention is transistors, probably because their parameters influence the Networks they drive, for example RF transistors often include Smith Charts.
    Very justified there, useless for us.
    Doubly doubt its presence on any Service (or Amp design one) is because, besides complexity , this used-refurbished unit carries a price tag of
    Price 3577A Agilent / HP 3577A 200 MHz Network Analyzer, Refurbished $3,695.00
    FWIW the current price tag for an equivalent modern one is
    https://www.keysight.com/en/pcx-x205...0&cc=US&lc=eng
    US$ 11,433 Starting Price*
    But that´s not the point ... IF it were that expensive AND its use were worth it, THEN it would find its way into Tech benches , one way or the other ... somehow I don´t see that happening.
    A small side note, since the HP3577 specs
    .001 dB, .005 degree, 1ps, .001 Hz resolution
    I can understand somebody used to such precision fumes and boils when watching sloppy 0.1dB change on anything and calls that a MAJOR change .
    We mere Mortals who can not get even near Olympus usually accept 3dB as a clearly detectable change and would be hard pressed to detect 1dB under very relaxed and stable conditions (as in: silent room and not a drummer within a mile).
    So we are 1000 to 3000 times "deafer" than such a marvellous Instrument .
    Why would anybody use a Network Analyzer to test a Guitar Amp capacitor?
    All I can think is (and this really belongs in the other thread):
    if all you have is a hammer, everything looks like a nail
    https://en.wiktionary.org/wiki/if_al...ks_like_a_nail
    Me? ... I am happy with a humble but faithful analog LCR Bridge
    which I have for over 35 years now and can give me all relevant answers, it only takes a couple minutes fumbling with controls, and if I were setting up a new Bench today I would find use for a digital Capacitance meter and an ESR meter which give instant results.
    Of course, Olympus Gods would sneer at such humble setups.
  29. #29
    Near Dallas Texas
    3,371
    Received: 12/0
    Given: 19/1
    Depending on the Tantalum cap.. many have ESR as high as 10 to 20 OHMS.... this will dampen any ringing in the square waves ... and make for a smoother guitar sound... In MIL design the Tantalum caps must always have some serious derating...
    In an oscilloscope, almost every power supply voltage is regulated, possible exception might be a fan. Those old Tektronix tube scopes were about half power supply. At some point in test or calibration, every power supply is tested for transient response and there is a spec that the supply has to pass. In the early 80's (when I worked there) Tektronix had to substitute Aluminum electrolytics for Tantalum caps on the output of regulated power supplies in most of their scopes because of cost. The capacitance was increased about 2X to get the impedance in the same range at high frequencies. The ESR of the Aluminum caps was higher and that damped the high frequency ringing.
    Tantalum caps have lower ESR at high frequencies, can operate at higher temperatures and they last longer. That's why they are used in high priced equipment that is meant to last longer that consumer gear. The only time I've ever seen a Tantalum cap derated was when they had to operate at extended temperature like in down-hole (oil well) equipment where they have to work at 200 degrees C.
    WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel.
  30. #30
    May 2007
    pacific north west
    13,199
    Received: 173/0
    Given: 241/0
    He's right about the high esr in some models though. especially some of the bullet shaped dry tants that I have used. They are indeed rated in tens of ohms (at least on the Mouser description). I suppose this anomaly doesn't apply to all tant caps, but I thought I'd point this out. I remember being surprised because I thought that by default I would get better esr with the tantalums. Turns out I have to pick through them. Not that it matters a whole lot with a cathode bypass cap. 20 ohms compared to 2 ohms across a 1500 ohm resistor!?! I'd need to hear it to believe there's an audible difference.
  31. #31
    May 2018
    San Diego, CA
    40
    Received: 15/5
    Given: 5/3
    The ESR in a cap makes a time constant against the value of the Cap....This is well known term call ESR ZERO .... because it puts a ZERO in the AC current loop transfer function... Do the math and figure it to see for yourself..
    The AC current loop would be through tube...through plate resistor...into DC bus...through de-coupling cap..to ground..then back through the cathode....
    This AC current loop will have a -3dB point at the frequency the impedance of the cap = the ESR ... This is 45 degrees of phase shift at this frequency...
    Even if this frequency POLE is above audio lest say 60kHz.... the phase shift at upper audio range is still significant and push the highs behind LAG the lower frequencies by 14 degrees at 10kHz... this is audible....
    Speakers do have audible range above the data sheet.... the speaker turns into a "tweeter" at higher frequencies... The voice coil, the wire and glue will resonant ... There is a frequency the speaker will no longer move...called the turn-over frequency...due to mechanical compliance limit....the speaker cone doesn't travel anymore,,instead the voice coil resonates and acts like a tweeter and square wave from a cranked and can sound harsh or smooth depending on the materials of the speaker...aluminum voice coil former vs paper would be an example...
    As for the 3577... It is an industry standard for many years and is solid... I bought 2 of them broken ...for $300 each.... I repaired one ...the second unit is sitting in storage have no time to fix it...Your welcome to it...I ll even supply the service manual...
  32. #32
    Senior Member Malcolm Irving's Avatar
    Dec 2014
    Derbyshire
    375
    Received: 20/0
    Given: 26/0
    … the highs behind LAG the lower frequencies by 14 degrees at 10kHz... this is audible....
    I don't think it would be audible to me, but maybe that's due to age and playing the guitar too loud! I think there is still a debate going on about the extent to which phase shift is audible. I suspect that where it is 'audible' it is probably only in the 'direction finding' sense rather than 'musical timbre' sense.
  33. #33
    30,129
    Received: 221/1
    I think it also relevant to mention we are discussing guitar amps and not hifi amps. What goes on at 10kHz in a stereo may well be audible, but in a guitar amp? Not so much. No one runs a sparkly tweeter in a guitar amp. Guitar speakers roll off an octave or more below that.
  34. #34
    Dec 2014
    Derbyshire
    375
    Received: 20/0
    Given: 26/0
    This AC current loop will have a -3dB point at the frequency the impedance of the cap = the ESR …
    I’m not sure if that is relevant to the triode circuit in question.
    At some low frequency the impedance of the capacitance is high compared to both the cathode resistor (and its own ESR). The impedance between cathode and ground is given by the cathode resistor. The stage is ‘un-bypassed’ at this frequency and has a lower gain.
    At some higher frequency the impedance of the capacitance is low compared to the cathode resistor but still higher than the ESR. The impedance between cathode and ground is somewhere between the value of the cathode resistor and the value of the ESR. We could call the stage partially bypassed at this frequency. The gain of the stage is now higher.
    At even higher frequency the impedance of the capacitance is low compared to its ESR. The impedance between cathode and ground is the ESR. Gain of the stage is maximum and we could call the stage fully-bypassed at this frequency.
    There is a point where the impedance of the capacitance is equal to its ESR, but nothing very drastic happens at that point.
    Depending on the values of capacitance, ESR and cathode resistor, the frequencies mentioned above (in practice) are down in the 10Hz to 2kHz region. At frequencies above that it is 'plain sailing' with a fully bypassed gain stage.
    2 Not allowed! Not allowed!
  35. #35
    Senior Member Pedro Vecino's Avatar
    Jul 2006
    Spain
    499
    Received: 4/0
    Given: 10/0
    In many Mesa amplifiers you can see 100 Ohms resistors in series with tantalum tubular cathode capacitors. I have never worried about understanding what function they have. The reason: sometimes I use that system to reduce gain and I have never used values lower than 390 Ohms. I'm sure that below that value I do not appreciate its effect (at least with my Fender and Gibson signal generators).
    But maybe it's related to what you comment.
  1. EMG tone cap
    By Brad1 in forum Guitar Tech
    Last Post: 01-01-2009, 08:06 PM
  2. How does Rk affect tone/gain?
    By Blindog in forum Theory & Design
    Last Post: 09-27-2008, 09:09 AM
  3. How do the metals in Alnico affect tone?
    By kevinT in forum Pickup Makers
    Last Post: 05-04-2008, 06:08 AM
  4. coupling cap & voltage divider question...
    By HTH in forum Theory & Design
    Last Post: 03-24-2008, 09:35 PM
  5. Filter cap voltage
    By grandmasterflash213 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-18-2007, 07:03 PM
