I'm interested in tracking down steel for the slugs in the MIM Jazz pickups. They're 5mm dia and plated and seems to add a lot of low end with the two ceramic bars at the bottom. Pickups measure 6.3K DCR and are very high output considering the lowish number of turns. I have similar magnets though I haven't tried swapping the magnets yet.
Which steel slugs for Fender MiM bass pickups?
I made some of my first pickups with the rods pushed out of MiM Fender Strat pickups! Then I got some plain steel rods from Home Depot.
I think Bruce is right, it's probably just plain cold rolled steel.
Any low carbon steel would do, and might sound better too. Try some 1010 rods, or something similar.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I've used 1018 and O-1 for poles. They both sound good, albeit it a little different.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
266213 Sigma/Aldrich
Iron
rod, diam. 6.3 mm, 99.98%
about $1/mm of length!
kidding, had a great time speaking with DK at the Handmade Instrument show this weekend, he is a mad genius!
The King Bass he brought was the most amazing 6 string fretless with effortless pinky access to the low string at the equivalent of the 24th fret due to a radical sculpted back...all feather light because of a Ti truss rod and CF in the neck...put the Pedulla Hexabuzz I have lusted after for years to complete shame.
once he masters pickups...look out!Last edited by tedmich; 04-27-2009, 10:38 PM.
De nada David!
I seriously did look into ultra pure and carbonyl iron for pickups, cobalt and nickle too, all the ferromagnetic elements, but 1018 at >98% Fe sounds just fine to me and the price is right (I am a chemist but not rich or crazy)
there are ranges in the composition of the cheaper steels,
1018
carbon (C):0.15-0.20%
manganese (Mn): 0.60-0.90%
phosphorus (P): 0.040%
sulfur (S): 0.050%
iron (Fe): balance
so low side 98.81% Fe, high side 99.16% Fe
(check my math but I think both numbers are >98% )
