I'm designing a power supply 460-0-460 w/ 5V4 rectifier tube. The data sheets says that typical value here is 10uf for capacitive input. What if I'm using a choke pi filter? I want to do 16uf-choke_16uf. Will the first cap need to be changed to 10uf? EG 10uf-choke_16uf?
Input filter cap value 5V4
Nah it should easily handle 16 if it handles 10.
BTW the 5V4 datasheet says 10uF, but the 5V4G says 60uF - which one have you got?
If you're worried about it, put a 1N4007 on the HT winding in series with each anode. That'll protect the PT if the tube shortsBuilding a better world (one tube amp at a time)
That first cap is what the tube sees. The fact you have a choke after it won;t diminish the size of the cap as far as the tube cares.Education is what you're left with after you have forgotten what you have learned.
Ok guys thanks for that. Not sure if I'll be using the 'G' version or not. Tubeswell, does the anode go towards the winding and the cathode towards the tube plates? Also, does this affect the rectifier function in any way, especially the sag factor?
Originally posted by lowell View PostTubeswell, does the anode go towards the winding and the cathode towards the tube plates? Also, does this affect the rectifier function in any way, especially the sag factor?
Anode (band) goes towards the plate. It doesn't affect the rectifier function in any way whatsoever. The tube will sag same as always. FWIW I've gone to doing this on all my tube-rectified ampsBuilding a better world (one tube amp at a time)
Radiomuseum.org
Originally posted by lowell View PostI'm designing a power supply 460-0-460 w/ 5V4 rectifier tube. The data sheets says that typical value here is 10uf for capacitive input. What if I'm using a choke pi filter? I want to do 16uf-choke_16uf. Will the first cap need to be changed to 10uf? EG 10uf-choke_16uf?
5V4, Tube 5V4; Röhre 5V4 (5V4)
Its not so much that the diodes will open, as that if the tube shorts, then it won't destroy the PT, because it won't hurt the diode if there is a 5V winding connected at the diode's anode end.Building a better world (one tube amp at a time)
Ok hmmm... so I'm trying to grasp this. Lets say the HT is 460-0-460 and then there's the 5V rect winding AND the tube is a dead short. So 5VAC on the anode side and 460VAC on the cathode side. I'm trying to understand this and correct me if I'm looking at it wrong. When the HT is swinging negative the 5V winding must also be, right? So the two windings are in tandom frequency-wise but obviously the HT is larger peak to peak. So this being the case, the 1N4007s are never forward biased. They just act as a buffer b/t eachother when the tube is shorted. I'm also assuming that the rectifier plates seeing pulsating DC is not a problem. The rectifier tube only conducts the positive half of the signal even when it sees AC? This'd make sense as the tube's name infers.
When a rectifier tube shorts and dumps high voltage AC power into the filter caps, the caps fail, and if they short, then this shorts the HT winding (because the rectifier tube is shorted). The diodes prevent thisBuilding a better world (one tube amp at a time)
Ok yeah so it's basically a "backup" rectifier in case the tube shorts. What I'm not totally clear on is how these diodes are only letting the negative pulsating DC through, and the rectifier tubes still functions the same. Is that the case? And if so, how does the tube flip that to positive pulsating DC?
Originally posted by lowell View PostOk yeah so it's basically a "backup" rectifier in case the tube shorts. What I'm not totally clear on is how these diodes are only letting the negative pulsating DC through, and the rectifier tubes still functions the same. Is that the case? And if so, how does the tube flip that to positive pulsating DC?Building a better world (one tube amp at a time)
Originally posted by lowell View PostThe band is the cathode and the anode goes to the HT...? I think that's what you mean. In your first reply here you said the anode was the band. Ok I get it, thanks!
R.G. Keen has a good article on this:
The Immortal Amplifier Mod - Premier Guitar"In theory, there is no difference between theory and practice. In practice there is."
- Yogi Berra
