Stageworks LG-8 PA
  • Stageworks LG-8 PA
    A teacher from a local elementary school brought this to me the other day. Two of the wires have come off the connector and looks like some sort of capacitor was soldered at the same two points where the wires connect.
    I can’t find any info on this P.O.S and I’m just wondering if I’m right?
    Gibson V + Seymour Duncan Hot P-90 =
    The mains power inlet?
    Like any amp, the hot and neutral would be the black and white wires, the third prong being ground, and that connects to chassis.
    The little blue discs look to me like varistors rather than caps. Transient suppressors. Looks like one between hot and neutral, and one between hot and ground. If they added a cap, the rectangular thing, I'd expect it across hot and neutral as well.
    Is your connector broken? It looks like the spring tabs are broken off. A new snap-in connector is readily available, they don;t cost much at all.
