Mojo tone montreux same humbucker parts ?
  • Mojo tone montreux same humbucker parts ?
    Hi All
    Does anyone know if the Montreux humucker parts 49.2mm are the same as the mojotone ones ?
    All the best
    Andrew
    The parts will be interchangeable but they are not the same baseplates at least.
    sigpic Dyed in the wool
      Hi Spence
      Do you know what the difference is between the baseplates is ?
      All the best
      Andrew
        The Mojos are better looking from the point of where the hookup hole is. However, they are probably more than 14% nickel and have huge clearance holes for the pole screws.
          Hi Spence
          Thanks for the info, I will probably go with the montreux.
          Cheers
          Andrew
            I asked Montreux a OEM list price and i received a list with the same price from his web minus 5% for U$500 and 10% for U$ 1K.Is it normal?
