A broken pickup?
  • A broken pickup?
    Okay, I know most people would tell me it is easy to work out when a pickup is faulty.
    I had a magnetic pickup from an acoustic guitar to look at. I thought the volume and tone controls on this pickup looked rather fragile so it is probable that I will find damaged pots.
    This wasn't the case at all if fact, next I wired the pickup directly to a jack and the only time I heard a peep from the pickup was when I touched the steel base plate (like a Tele pickup.)
    Next came the Fluke 77 multimeter, it told me the pickups resistance was 7.7K, I thought this would be typical of a single coil pickup used for this application.
    I even made sure there was a magnetic field from the bar magnet at the core of the windings.
    So why would it measure 7.7K and I'm not hearing a peep from it?
    Yours Sincerely
    Mark Abbott
    Need more info. Brand of pickup? When you say a peep, in what way? If you tap the top of the pickup with something ferrous does it make a sound? ...and not to be insulting, but other people with problems may be reading this for centuries to come..... did someone install a magnetic soundhole pickup on a classical guitar with Nylon strings? I've seen that one before
      I can't see any brand on the pickup. It just states acoustic guitar pickup.
      The pickup came off a steel string guitar and I put the pickup up close to the strings of my electric guitar to see if it worked.
      Regarding the peep. When I touched the base plate, I heard noise as if I was holding the tip and earth of a lead. The plate was attached to one side of the coil, so it is understandable that I'd hear noise when I touched the plate.
      Mark
        Yeah, me too!
        Pepe aka Lt. Kojak
        Milano, Italy
