Can they be interchanged?
6v6, 6f6
Pin-out's the same. Bias is about the same. Plate voltage might need to be watched but it shouldn't be an issue with a 5F1 if you were idling the plate at about 340 I reckon. The recommended plate dissipation is 4.5W, so just run a slightly higher cathode resistor, and/or zener down the B+ a bit if it redplates.
6F6GT/G @ The National Valve MuseumBuilding a better world (one tube amp at a time)
