Page 2 of 2 FirstFirst 12
Results 36 to 43 of 43
Thread: PJ bass wiring problem
  1. #36
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,074
    Received: 17/0
    Given: 8/0
    I've had to deal with this a few months ago , I think a switch to switch between the pickups would correct the problem with the canceling when both volumes are on full.
  2. #37
    Nov 2010
    DC
    140
    Actually, I just drew it all out and it appears you can get all strings INPHASE with both on. Example, my J is south-up. The P is south-up on the low strings and north-up in the high strings. Therefore, if the J is CW, the high string P is CCW, and the low string P is CW then you should get RWRP high strings and in-phase, but not humcancelling, low strings. This is what I believe I have as I mentioned earlier a wire-swap of the J made things worse... especially the high strings... aka: OOP. This still doesnít address why thereís a dull drop with both maxed though... sigh.
    Copperheadroads, why do you believe a switch would work better than 2 volumes? I donít follow?
  3. #38
    Nov 2010
    DC
    140
    OMG!!! I wish I had just done this exercise earlier!!! I went and actually investigated better... hereís whats going on:
    J: south CCW
    P low: south CW
    P high: north CW
    WHOEVER WOUND THIS PICKUP SCREWED UP THE WIND DIRECTION OF THE P LOW!!! So much time wasted... :|
    Chris
  4. #39
    Supporting Member StarryNight's Avatar
    Oct 2008
    Victoria, BC Canada
    402
    Quote Originally Posted by verhoevenc View Post
    Chris
    the wind direction of both coils can be the same if the start of one coil is connected to the start of the other (or end of one connected to the end of the other). It will be humbucking.
  5. #40
    Nov 2010
    DC
    140
    Sorry, I should have been clearer. Yes, both winds can be same direction and still work as long as the leads are hooked up right. These leads were not hooked up right hahahah. At least itís a fairly simple fix.
    Chris
  6. #41
    Jun 2009
    2,074
    Received: 17/0
    Given: 8/0
    Actually, I just drew it all out and it appears you can get all strings INPHASE with both on. Example, my J is south-up. The P is south-up on the low strings and north-up in the high strings. Therefore, if the J is CW, the high string P is CCW, and the low string P is CW then you should get RWRP high strings and in-phase, but not humcancelling, low strings. This is what I believe I have as I mentioned earlier a wire-swap of the J made things worse... especially the high strings... aka: OOP. This still doesn’t address why there’s a dull drop with both maxed though... sigh.
    Copperheadroads, why do you believe a switch would work better than 2 volumes? I don’t follow?
    Look up something called "insertion loss"
  7. #42
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,946
    Received: 2/0
    Given: 3/0
    Sorry, I should have been clearer. Yes, both winds can be same direction and still work as long as the leads are hooked up right. These leads were not hooked up right hahahah. At least it’s a fairly simple fix.
    Chris
    I've seen P pickups done both ways. P basses only have one pickup, so the two halves don't have to be in phase with a second pickup.
    But the other issue with a P/J setup is they just don't match very well. The P overpowers the J.
    It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. ó Albert Einstein
  8. #43
    Nov 2010
    DC
    140
    Sure, but this was given to me as a PJ set so I would have thought that that would be taken into account.
    As for the "overpowering" comment, I sort of agree. It was a fun little project but in the future I probably won't do any more PJs unless asked to.
    Chris
  1. Hi there...and wiring problem/dilemma
    By razorcut in forum Music Electronics
    Last Post: 05-19-2009, 01:23 PM
  2. help please! wiring diagram 4 electric bass
    By camg in forum Music Electronics
    Last Post: 05-20-2008, 04:14 AM
  3. Fender Power Jazz Bass Special wiring
    By Axtman in forum Guitar Tech
    Last Post: 04-01-2008, 04:57 AM
  4. Bass Pickup Wiring
    By jtucker69 in forum Guitar Tech
    Last Post: 03-31-2008, 10:40 PM
  5. Passive Bass Wiring
    By iassael in forum Guitar Tech
    Last Post: 01-09-2008, 02:53 AM
