Vox AC30 build for me
  • Vox AC30 build for me
    Hi Guys
    I have just joined this forum and glad to find it.
    I am starting a project from the ground up to build a Vox AC30 clone with top boost circuit. This will be my second amp ...... the first being a 100w transistor kit I bought a few years back. It absolutely screams but I want to get a tube amp.
    I have found a large number of drawings for AC30s around the various schematics sites but their image quality actually ends up being a bit poor for some component values....... all are hand drawn.
    Does anyone have a clear circuit diagram and a parts list I could have please?
    For schematic / layout, see
    https://taweber.powweb.com/store/kits_60b.htm#6V30
    Also, if you scroll to the top of the page, there's a links for BOMs.
      Thanks so much for this web site and your kind help. These plans look exactly like what I want
        Hoffman AC-30
        You can find a layout for a Hoffman type AC-30 here:
        http://www.el34world.com/Hoffman/images/AC30.gif
        Schematic is attached. This does not have vibrato. I also drew up a layout with paralleled terminals (which is what I normally use) but check it against the schematic for errors.
        with respect, Tubenit
          AC30 Reverb DRAFT
          Here is a reverb version DRAFT that I have NOT built for your consideration. I have used this type of reverb on numerous amps successfully. Compare the schematic and layout & check for errors.
          I think this would work but again I haven't built it so consider this a DRAFT only.
          With respect, Tubenit
            Thanks heaps ............ greatly appreciated
