Originally posted by belwar
View Post
Wal MK1 Pickup Construction
Originally posted by David Schwab View PostWhere did you find that? The Hiscock book? That's not in mine. I must have an old edition (the cover is different as well).int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.com
Originally posted by mkat View PostYep, it's in the 2nd edition p.157.
Here's some of my Wal clone bobbins. I have all the parts made... now I just have to assemble the pickup.
Originally posted by belwar View PostGood! All the more reason for people to make aftermarket pickups!
What you can't do is buy Wal pickups for non Wal basses. That's why I'm making them in MM covers.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by belwar View PostMaybe other makers will start using that wal shape. Who knows!?
That's probably why Bartolini has a half a million shapes! Trying to keep up with all the proprietary designs.
If Wals were more common, then you might see that happen.
The other thing about using that shape is, what bass would it fit into, and does the string spacing match?
If you are making the bass and the pickups, then it doesn't matter what you use, which is what they did.
Their early basses had Fender Mustang and Guild pickups!It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I know there´s alot of people that want a Wal, but they are very expensive so not many can afford...starts at £3200 and the secondhand market is even more expensive! So a aftermarket pickup that anybody can put in their bass to get a little Wal sound, is probably gonna sell!
Originally posted by Evilbiker View PostSo a aftermarket pickup that anybody can put in their bass to get a little Wal sound, is probably gonna sell!
Wont make your bass sound like a Wal though.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Gauss Readings
I measured the gauss readings off the poles of two pickups today. Here they are for posterity (did I even spell that right)?
Mk1 Bridge Pickup- South Towards Neck
- Top row of poles from bass to treble side 698, 617, 655, 739
- Bottom row of poles from bass to treble side 892, 810, 670, 705
Mk3 Neck Pickup- South Towards Neck
- Top row of poles from bass to treble side 676, 800, 792, 800, 842
- Bottom row of poles from bass to treble side 742, 763, 776, 823, 740
Enjoy.
