redoing a couple fender cabs that stewed in katrina water - not a restore really just a redo, not worried about correctness, just function - baffle boards for these - both are either black or sliverface period - do i understand they used particle baffles on these ? - what was the thickness for a 2-10 possible vibroverb, for a 4-10 possible concert type - not really a fan of particle, thinking of going with the baltic birch - would 1/2" baffle work for these or do i need to go thicker? - i think the last time i posted anything was on the old site! - thank you - oo3
baffle board size
If they are BF era cabs they should have had plywood baffles. 4x10 cabs (like the Bassman and Super Reverb) used 5/16" but there were others that used 3/8". I have used 1/2" marine plywood (actually measures 3/8") with good results. Baltic birch should be great. I have never seen a BF amp with a MDF baffle but I have seen the less expensive SF models (specifically a Vibro Champ) with MDF baffles. I don't know much about the other SF models. But I did look in the back of a SF Twin Reverb that IIRC had a plywood baffle.
FWIW a popular mod is to change the baffle on some Fender combo's to a non floating type made of thicker material, like 3/4". It's better for bottom end and gives a more overall solid kind of sound with less acoustics and anti phase from the baffle itself.
Chuck"Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostIf they are BF era cabs they should have had plywood baffles. 4x10 cabs (like the Bassman and Super Reverb) used 5/16" but there were others that used 3/8". I have used 1/2" marine plywood (actually measures 3/8") with good results. Baltic birch should be great. I have never seen a BF amp with a MDF baffle but I have seen the less expensive SF models (specifically a Vibro Champ) with MDF baffles. I don't know much about the other SF models. But I did look in the back of a SF Twin Reverb that IIRC had a plywood baffle.
Chuck
The question about high density particle board baffles is open and I'm not arguing it ... I think most all of them were in fact particle board during and after the black face or silver face era and an odd thickness of about <5/8", plus, (with respect to the full floating black face baffle boards) the 1/4" plywood strips to hold the grille cloth off the actual baffle board.
There might have been some super heavy Twins or Super Twins with plywood but (although I can't be sure), I don't think so.
Tweed era amps were almost all 5/16" to 3/8" Douglas Fir plywood with the 1/4" plywood strips and used light weight AlNiCo speakers.
I have two black face Pro Reverb amps (1965 and 1967), a 1969 silver face Vibrolux and a 1973 silver face Deluxe Reverb in the shop right now and all four, in fact, are using 1/2"-5/8" thick particle board baffles.
"If they are BF era cabs they should have had plywood baffles."
O.K... I read that. I have worked on a Super Reverb that had it's baffle changed to 3/4" ply. So I thought it must be correct that the BF amps used plywood. I do know that the 4x10 Bassman baffle info is right though.
As I recall Bruce corrected me on a Princeton transformer Q about a year ago. Something else I had read and thought was correct. It's a good thing Bruce is around or who knows what kind of misinformation I might re-print...
It's true enough that the only way to really "know" anything is to have experienced it yourself... But, FWIW, I do think plywood is the way to go.
As for the 1/4" strips to suspend the grill cloth, that is how I did my last cabinet design and it worked out well. But I prefere my other designs that have a seperate grill on Velcro tabs.
Originally posted by oo3 View Postredoing a couple fender cabs that stewed in katrina water - not a restore really just a redo, not worried about correctness, just function - baffle boards for these - both are either black or sliverface period - do i understand they used particle baffles on these ? - what was the thickness for a 2-10 possible vibroverb, for a 4-10 possible concert type - not really a fan of particle, thinking of going with the baltic birch - would 1/2" baffle work for these or do i need to go thicker? - i think the last time i posted anything was on the old site! - thank you - oo3
