Need advice on adding an ext speaker cab for 1980 Peavey Mace
  • Need advice on adding an ext speaker cab for 1980 Peavey Mace
    I have a 1980 Peavey Mace VTX w/ 2- 12" Black Widows (original spkrs).
    The manuals are confusing... one Mace manual says I can add a 4 ohm load which would create full 2 ohm power and states the Mace has a 4 ohm output on the orig spkrs.
    A Mace/Deuce manual states that 8 ohm or 4 ohm loads can be added.
    My Mace has 1 Main and 1 Aux jack that is labelled 4 ohms. So I'm assuming adding a 4 ohm cabinet is perfect. This would give me 160 watts @ 2 ohms.
    Can someone recommend a good nowadays 4-12 cab to use and how to rewire since all new cabs seem to be 16 ohm?
    Thanks!
    [url]www.myspace.com/mickradar[/url]
    16 ohm 4-12 cabs have 4 16 ohm speakers. They are wired in series - parallel. wire all the speakrs in parallel and the impedance will be 4 ohms. Might want to check the forum for threads concerning wiring speakers.
