Ok, so I'm having a hard time getting a post PI buffer duo to work. I've read in some sources that this buffer placed post the PI will make the sound even sweeter. I've seen em used in some multi-powertube amps as the Fender Studio bass, Super Twin Reverb, the HiWatt 400W and the Ampeg SVT (if I'm correctly). I've also seen in some books the use of the tube buffer.
When I want to add it to my newest build all I get is some compressed sounds from it with a sort of tremolo feeling in attack / decay. I've used both 12AT7's as 12AX7's for this tube.
When I remove the buffer the amp works perfectly.
Output section
The PSU that goes with that
Any thoughts? Should I just remove the buffer and keep the amp the other way? Or try another design? I tried several different designs, all give the same outcome. I triple checked my build and it's fine!
Output section
