Lase Dually Wiring Code?
  • Lase Dually Wiring Code?
    I'm trying to build a custom wiring harness series/parallel/phase switching for a customer and I'm really confused with the Lace color coding. Some have two orange and two whites, others have orange, white, orange w/black stripes and white w/ black stripes. All I know is that green is ground. My customer has the pickups and I have no idea how to tell him to hook them up.
    What I need is:
    1- What color is start for north coil
    2- What color is finish for north coil
    3- What color is start for south coil
    4- What color is finish for south coil
    5- Are both coils wound CCW like a "normal" humbucker or are they reverse wound from each other?
    I'm sure that someone out there has run into this and any help would be appreciated! Thanks in advance...
    -Stan
    -Stan
    ...just transferring wire from one spool to another
    Stan Hinesley Pickups
    FaceBook
    Lace has wiring diagrams on their site. I don't see a Dually listed, but since they are two regular single coils, you might still find something useful.
    http://www.lacemusic.com/wiring/wiring.php
      Thanks for your reply David. Man, can't believe I misspelled Lace!
      -Stan
      -Stan
      FaceBook
