KMD Analog Delay pedal
  • KMD Analog Delay pedal
    I just picked up a used KMD analog delay - works great with 9 volt batteries but I cannot find an adapter to work with it.
    Can someone tell me which adapter I should use?
    thanks
    I'd be shocked if it didn't use a standard Boss style 2.1mm barrel jack with a negative tip.
      None of the pictures of KMD pedals at effectsdatabase, or any of the images I was able to find on-line. show the rear skirt, so it cannot be confirmed from them that it is indeed what eurekaiv suggests. But based on those pictures and the clear attempt to provide a Boss-like package, I too would be very surprised if they were not compatible with the same things Boss pedals are.
        According to this "review" it does indeed use a Boss style power supply arrangement.
        NoiseGuide - KMD Analog Delay
