Anyone have a pic of a DiMarzio and/or Duncan hex polepiece? Do they have heads or are they a consistent diameter? And can anyone point me to a supplier?
Hex Pole Pieces
They have threads. If you have a local screw and die shop, they should be able to get you what you are looking for. I once got some with a cone on the down side and put them in upside down, so at the top of each pole there was a little dish out. Looked better in my head than it did in real life ;]
Originally posted by Stan H View PostTouchy subject I know, but GJ has them...I'm just sayin'...
But by looking at the tiny picture on the GJ site, it appears they are more like adjustable slugs with a consistent diameter (headless). Are they 5-40? I'd send Pat an email and ask but...
Dimarzio uses both styles. The Super Distortion, Super 2, Super 3, Evolution, Evo 2, Blaze, all use a "slug" bobbin and the bolt is like a "set screw" in that it's solid all the way down, threaded all the way down with a cone/cup tip. The other hex poles, on things like Tone Zone, Fred, PAF Pro, etc. are narrower, "screw" bobbins with keeper bars, and are only thicker at the head, just like a slotted screw pole. Our Full Shred and Screamin' Demon pickups use a hex head like that with a keeper bar, but our screws are shorter, so it's more like when someone cuts the bottom of their screws off to mod their pickup to be tighter and punchier sounding. Anyway sorry for the long rant but you need to know what kind of bobbin you're putting them in to know what diameter/style of screw you'll need.
Originally posted by frankfalbo View PostDimarzio uses both styles. The Super Distortion, Super 2, Super 3, Evolution, Evo 2, Blaze, all use a "slug" bobbin and the bolt is like a "set screw" in that it's solid all the way down, threaded all the way down with a cone/cup tip. The other hex poles, on things like Tone Zone, Fred, PAF Pro, etc. are narrower, "screw" bobbins with keeper bars, and are only thicker at the head, just like a slotted screw pole. Our Full Shred and Screamin' Demon pickups use a hex head like that with a keeper bar, but our screws are shorter, so it's more like when someone cuts the bottom of their screws off to mod their pickup to be tighter and punchier sounding. Anyway sorry for the long rant but you need to know what kind of bobbin you're putting them in to know what diameter/style of screw you'll need.
If 5-40 x 3/4" length is your need you can get grade 8 steel here for $.18 ea
MSC Item Detail
If you sign up for MSC sale emails, you'll get a regular 40% off coupon code.Last edited by David King; 01-29-2010, 02:13 AM.
for slugs
I found that #10 sets screws are the same size and wrench as the 5-40 allen screw heads, and fit nicely in a slug bobbin, cutting their own threads as they go.
McMaster has 5-40 threaded set screws, check out their website and visit the set screw section, they pretty much have everything you need. I don't know what alloy any of that stuff is though, the ones you want just say "steel."http://www.SDpickups.com
Stephens Design Pickups
Originally posted by Possum View PostMcMaster has 5-40 threaded set screws, check out their website and visit the set screw section, they pretty much have everything you need. I don't know what alloy any of that stuff is though, the ones you want just say "steel."
Also, McMaster buys from multiple makers to a single McMaster-written spec. McMaster supplies good stuff, so their customers generally trust them and don't insist on knowing who made what.
Hmmmm, hardened screws aren't a good idea for pickups. You'd just have to try them and see what they sound like.http://www.SDpickups.com
Cup point steel with black oxide finish will be the cheapest by far usually.
Cup point stainless won't generally be magnetic so not much use but still reasonably priced.
McMaster-Carr
I never would have guessed that McMaster Carr would be the cheaper source.
