Removing powertubes and running
  • Removing powertubes and running
    Will it hurt an amp if you pull the power tubes and leave the amp turned on for awhile?
    I do it for testing, a friend and i are just settling an argument
    Thank you
    No.
    Voltages will be slightly higher though. Make sure the filter caps are rated high enough.
      its a fender bassman with 100uf 450v, and 20uf @ 500V
      think thats enough?
        Yes.
        To be 100% sure, you can pull the power tubes and measure the voltage across each cap. A couple of volts too many for a minute or two will not destroy them (say if you measure 505V on a 500V cap).
