hi Guys, need some help, my rage 158 not sound, please post peavey schematic.
Paevey Transtube Rage 158
Hi, welcome. Contact customerservice@peavey.com and ask for the schematic. Include the serial number and any other information from the serial number plate. For example, sometimes they update the circuit, and add a year to the serieal number plate.Education is what you're left with after you have forgotten what you have learned.
Thanks for that post, but that won;t match his amp. His is a Transtube version, which is most all transistors instead of the op amps.
There is Rage, and Rage 158 and Rage 158 transtube, and, I suspect, more.
here, this might be the one.
Blazer and Rage use the same circuit board, the Blazer adds the reverb. Ignore the missing reverb parts in the amp.Attached FilesEducation is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostThanks for that post, but that won;t match his amp. His is a Transtube version, which is most all transistors instead of the op amps.
