How to remove knobs from Line6 DL4????
  • How to remove knobs from Line6 DL4????
    I had a problem with 2 of the switches of my DL4, the inner part "unscrewed" (sorry, i dont know how to say it, I'm not english) and now is moving inside the pedal and the switches are useless, i tried to remove the main board to get to the part to fix it, but i guess i have to remove the knobs in order to move the mainboard...
    Does anyone know how to remove the knobs without braking them???
    HELP ME PLEASE!!!
    I used a small skinny plastic screwdriver to pry each side of the switch slowly up. They pull right off but can be a little stubborn sometimes.
      Thanx it worked!!!
        Glad to hear. Also I meant to say knob not switch
          IC Puller. The little folded spring steel thingy with the plastic grip. This.
            That might work but the ones I've come across are really stuck on there. I couldn't pull them off with pliers without totally messing up the knobs.
