Aluminium TO3 insulators??
  • Aluminium TO3 insulators??
    I have a Carlsbro with a pair of to3 style output transistors (MJ15022's) and the insulators seem to be aluminium with a thin plastic coating? Has anyone come across these and do they tend to short? (im replacing them with normal mica ones, i just wondered out of curiosity)
    Maybe. Hard-anodized (that is, sapphire coated ) insulators were common at one time. I can well imagine that a hard plastic coating would work too.
      You don't see those TOO often, and I am glad. Though anodized aluminum has non-conductive surfaces, they would DEFINITELY conduct if something penetrated the anodized layer. I always go with regular ol' mica for this reason.
      John R. Frondelli
      "Mediocre is the new 'Good' "
        I prefer the Sil-pad things. These don't bleed goo and are insulating to several hundred volts or more. Easy to work with and about the same thermal resistance as gooed up mica.
          I refuse to use Silpad's unless there is no other choice. I've seen several instances of TO-220 and other tab-style heat sinks cut through them causing a short. If there is a burr, you can be screwed in the long run. I will also purchase most of the tab-style semiconductors in the FullPack version, which runs the epoxy case over the back of the heat sink tab as well, eliminating the need for an insulator, just grease.
          John R. Frondelli
