Wiring Advice Needed - 5-way switch, 3 HBs, coil-split
  • Wiring Advice Needed - 5-way switch, 3 HBs, coil-split
    I've got a Schecter Hellcat VI that has three mini-humbuckers, a 5-way switch, and a push/pull pot for coil-split. Here's a link to the wiring diagram:
    http://www.schecterguitars.com/schem...HELLCAT_VI.pdf
    My question is, can I modify the wiring so that the middle pickup splits to the other coil so that in the 2 & 4 positions the split coils are hum canceling?
    Thanks!
    Mark
    i dont think you can with that setup, but if you wanted to, i think you can add a couple of mini switches to get that setup
      You can do it if you use one of those 4-pole Super Switches.
      STEWMAC.COM : Super Switch
      This would allow you to use what ever coil you wanted on the splits.
      You just have to come up with the circuit.
      I did something similar recently by modifying a Megaswitch.
        Re :Wiring Advice Needed - 5-way switch, 3 HBs, coil-split
        Thanks!
        Mark
        Hello Mark :
        I'm interested in what you ended up with ?
        I want to add a 3rd hmbr to my axe too .
        Hurricane Ramon
