I was wondering if anyone has done this. My fingers are kinda huge, size 13 ring finger. I have a nice taylor acoustic that I love playing. I was wondering about changing a 7 string electric over to 6 string to more nearly match my acoustic. That way I could get a wider neck without paying custom shop prices. This would just require changing the nut and removing part of the bridge. Anyone done this?
seven string to 6 string mod?
Surely you're going to have to get a new bridge? If you just remove one of the saddles, the others won't be evenly spaced any more. If you find the right kind of bridge, you could drill a bunch of new holes in the back to anchor the saddles in the right places.
Nut and pickups should be no problem, but you'd want to try and get 7-string blade pickups. 6-string ones will be too narrow, and regular 7-string ones will have 7 pole pieces.
I have pretty big fingers too. I can't play an ES-335 style guitar because it's too narrow at the nut: I can never fret just one string without buzzing the others. But a Strat suits me fine, they're considerably wider at the nut than a Gibson-style guitar.
You could have great fun making yourself some kind of Franken-axe out of Warmoth parts."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
When you go to convert a 7 you'll find yourself with a bridge with adjustable saddles that will need to be either replaced or completely re-engineered to spread the six strings evenly. The headstock won't align with anything once you cut the nut.
It's an ugly fix.
You should be able to find a bolt-on neck with a 1-3/4" nut width. I'd go from there. Or find or commission a custom build. It won't be more expensive than starting with something wrong.
