i built a couple of humbuckers for a guy ,i never had any nickel baseplate at the time so i made them out of some hard plastic i had on hand . the wax pot did not warp them at all . they turned out really nice he love the sound nice and bright not to muddy . i was wondering would the baseplate need to be shielded
does a non metal base plate need shielding?
adding shielding may negate whatever sonic advantage there is to using a non-metal material. Or it might not. It is more important that conductive materials be always grounded, rather than all parts always being shielded.
They'd only need shielding if he says they are too noisy, in which case shielding the cavity would probably make more sense.
Originally posted by FunkyKikuchiyo View Postadding shielding may negate whatever sonic advantage there is to using a non-metal material. Or it might not. It is more important that conductive materials be always grounded, rather than all parts always being shielded.
I would be more concerned that the plastic baseplate was not a ferrous metal (i.e., attracted to a magnet). Like on a traditional tele bridge pickup with a metal baseplate, I believe it has an effect on the magnetic field created by the pickup. But if it sounds good, what the heck... a lot of the newer tele bridge pickups do not have the metal baseplate and people seem to like them.
Steve AholaThe Blue Guitar
www.blueguitar.org
Some recordings:
Originally posted by Steve A. View PostI would be more concerned that the plastic baseplate was not a ferrous metal (i.e., attracted to a magnet). Like on a traditional tele bridge pickup with a metal baseplate, I believe it has an effect on the magnetic field created by the pickup. But if it sounds good, what the heck... a lot of the newer tele bridge pickups do not have the metal baseplate and people seem to like them.
But that;s a single coil pickup, so the poles on the bottom of the pickup are touching the plate. If you did that on a humbucker you would "short out" the magnet, sam as stacking a piece of steel between the pole pieces would.
There is no need for a humbucker to have a metal base. That was probably done for shielding purposes. But some humbuckers don't have it, like Bill Lawrence.Last edited by David Schwab; 05-22-2010, 04:53 PM.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
