Can anyone recommend a good glue/adhesive for attaching maple/plastic spacers to the baseplate as well as attaching magnets?
Glue
Tags: None
Originally posted by kevinT View PostCan anyone recommend a good glue/adhesive for attaching maple/plastic spacers to the baseplate as well as attaching magnets?
I've never glued the spacers or magnets in a humbucker.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I disected a stock pickup out of an Ibanez. It looks as if they used some kind of glue along the edge of the bobbin on the inside where they touch the mag. I tried scratching it off with my fingernail but to no avail. Its hard and shiny and its not wax. There is wax present. They didn't use anything on the bottom where the mag and baseplate touch.
just wondering if anyone else here does something similar...i.e., gluing bobbins to mag and/or baseplate.
I glue the spacers, I don't glue the keeper bar nor mag. As you said, good bobbin attachment screws and potting pretty much tighten up those loose ends.
I use superglue to glue my spacers, but I use plastic spacers. I also use stick glue on my magnets. I've been thinking about switching to using beeswax instead of stick glue. I've found that putting something on the magnets helps with feedback supression.
Originally posted by kevinT View PostI disected a stock pickup out of an Ibanez. It looks as if they used some kind of glue along the edge of the bobbin on the inside where they touch the mag. I tried scratching it off with my fingernail but to no avail. Its hard and shiny and its not wax. There is wax present. They didn't use anything on the bottom where the mag and baseplate touch.
I glue the spacers, I don't glue the keeper bar nor mag. As you said, good bobbin attachment screws and potting pretty much tighten up those loose ends.sigpic Dyed in the wool
Poison trap
Depending on the model Im making, sometimes I use a super thin tape between the magnet and the baseplate. The magnet never touches the baseplate. I also like the epoxy....putting it over all the solderd conections befor I tape, and Its a reall bitch to get off therefore resulting in a cut on the wire. Like a automatic boobytrap for prying eyes. Any alteration voids my warrenty therfore........Protecting the design is essential. What a bastard I am.
Originally posted by NightWinder View PostProtecting the design is essential. What a bastard I am.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
