sorry to beat this horse again but I just got a new DMM and wanted to try measuring resonant peak with my iPod frequency sweep app (I had tried this previously with no luck but that was due to some wiring errors and using a basic DMM). I have followed Joe G's diagram and with the iPod being used for the sweep and I'm getting a reading on the DMM but I'm not seeing the peak as the AC voltage drops as the frequency goes up. My question is if I measure between 4000Hz and 14000Hz I get a steady voltage readings between .775 and .460 VAC - does this sound right as far as having enough voltage for this method? I also plugged the iPod into a small mixing board to get a hotter signal and the meter was at about 1.7VAC but I still did not see any changes on the DMM other than a steady decrease in voltage. This question is obviously coming from a complete novice so I might be missing something painfully obvious!
another resonant peak question
Yes the DMM has a frequency response, most will only measure voltages/currents accurately up to a few hundred Hz. Think about it, if you try to measure a 1V signal at 60Hz and then another signal 1V at 1MHz, will a cheap meter display both as being 1V?My band:- http://www.youtube.com/user/RedwingBand
