Looking to build a solid state power amp. Class D?
  • Looking to build a solid state power amp. Class D?
    What's a good chip to base this on? I'm looking for something I gig with, something that's pretty clean sounding.
    I've seen the TDA2040, which is 22W at 18V, but I think I might need more power than that.
    Class D IC
    TDA 7482
    Class D
    25W
    Datasheet:http://www.datasheetcatalog.org/data...onics/5200.pdf
      Well that's not significantly more powerful, right? I need something that will remain reasonably compact and clean but still get over drums.
      Thank you for the suggestion, though.
        What about this?
        Free Schematic Diagram at www.circuitdiagram.net
        Where do I go about getting a bipolar power supply like that, though?
          http://www.st.com/internet/com/TECHN...CD00002355.pdf
          This guy will do 40Watts. Class D.
          That link that you supplied is used on a lot of amps.
          Marshall comes to mind.
          There MG stuff.
          It is a class AB amplifier ic.
            If you want Class D, buy a ready-made module. It's hard to do properly.
              Also search (here) for the Crate Power Block schematic, it has 2 x 75W/4 ohms class D channels.
              That said, it's complex and even they, with all that corporate muscle behind, had to drop it.
              Maybe a nice old technology AB amplifier, such as an LM3886 fills the bill.
                Actually I own a power block, but I was hoping to find a more compact design that that. Haha.
                  WTF
                  Or, to state it better, since I did not find the *very* surprised/dumb smilie I was looking for:
                    I don't see why it's so confusing. Something as big as the EHX 44 Caliber would have been cool.
