I'd love to find a replacement.... Body is 88mm long, screw centers are 80mm, 60mm travel, 10k Audio, knob slides on.... Mouser only has linear... I realize I could always install rotory pots, but that would be ugly....
Where can I find a 10k Audio slider control for my old Carvin
What is bad on the old one? Usually the handle breaks off the little shuttle inside. If you can find another slider of th same make and similar model, you can disassemble that and take its good shuttle out and install it in your old slider.
Go over to geofex.com and look up "the secret life of pots". perhaps you can create a more suitable taper with that Mousre linear and some external resistors.Education is what you're left with after you have forgotten what you have learned.
