43 AWG PE
  • 43 AWG PE
    I am not sure if this is the right place to post this, but I am looking to buy some 43 awg PE. I have called around and I cannot get just a pound of it with out getting slaughtered. Does anyone here have a pound or so they want to unload?
    Robbie
    Robbie
    I needed 42 & 43PE a year ago and I bought it from MWS.
    I had to buy 5+ Pound rolls of each.
    If your going to wind much its cheaper in the long haul to bite the bullet and get the big Roll.
    This was the prices back in October.
    10/7/10
    42 spn 7lb min $18.32
    42 hpn 6lb min $21.64 - heavy build poly
    42 heavy formvar 5 lb min $28.51
    44 spn 6lb min $28.34
    43 plain enamel 5lb min $36.96
    42 plain enamel 6lb min $32.35 per lb
    You Can contact MWS at
    MWS Wire Industries
    PH (818) 991-8553
    FX (818) 706-0911
    Good Luck,
      AWG 43-Ga Plain Enamel Single Build Pickup Coil Wire 1/2 lb Spool
      Personally for the same amount of money I'd get this:
      AWG 43 Copper Magnet Wire SPN 155 Red - eBay (item 250797173824 end time Apr-07-11 07:52:02 PDT)
      1/2LB vs. 1.56LB. PE is always expensive
        I was considering picking up that one on eBay, but I cant decide whether PE is really worth the effort/cost.
          If your just making pickups, use the SPN, if your making vintage pickups with exposed coils and the look is important, buy the PE.
          PE is harder to wind by hand, its harder to see. Good Lighting is a must. Red SPN and Clear Formvar are the easiest to use.
          The 43 PE and Spn should sound real close.
            Thanks man, all I needed was a little added direction. I am gonna pick up some of that stuff on ebay. I am pretty excited about this new hobby. I normally build guitars, but the cost of making them is killing me.
            Robbie
              Robbie
              Sounds good. Be sure to check out our SubForum the Beginners Corner.
              I hang out there a lot. It's not just for Beginner's, Check it out!
              We all try to keep a lot of basic winding info going there also.
              Later,
              Good Luck!
                I agree with Terry ,go with the SPN
                If you want a clean tone that sounds like having a dozen blankets over your amp thy this
                AWG 48 Copper Magnet Wire SPN 155 Red - eBay (item 230603275672 end time Apr-06-11 10:47:08 PDT)
                Just kiddin go with the awg 43
                  Do MWS have a minimun quantity or price order?
                  jairo eduardo suarez gallardo
                  mm basses -only exotic woods from Colombia-
                  mm basses
                    Yes.
                    Read below.
                    10/7/10
                    MWS Wire Industries
                    PH (818) 991-8553
                    FX (818) 706-0911
