Page 4 of 4 FirstFirst 1234
Results 106 to 139 of 139
Thread: Klemt Echolette S
  1. #106
    Mar 2015
    In France, near Bordeaux
    33
    Sorry...sorry...sorry!
    Contrary to what I thought , I had too many pre-magnetization on the
    three recording heads .
    I inserted a 500k potentiometer between 60pf capacitor , 120pF and
    220pF and heads, and thus I was able to adjust the pre- magnetizing
    voltage applied to each recording heads .
    It is true that these heads , instead of presenting a resistance of about
    1,000 ohms are only 300 ohms , and I gather that the HF voltage that
    was applied to them was too high.
    So I consider that my problem is solved.
    Sorry to have bothered you with my question ...
  2. #107
    Mar 2015
    33
    Hello
    My old NG-51S that i used with my orchestra in 60' & 70' is now in working order.
    You can see, below, some pictures of it.
ID:	37828Click image for larger version.
ID:	37829Click image for larger version.
  3. #108
    Old Timer oc disorder's Avatar
    Jul 2006
    Land Down Under
    1,267
    Received: 1/0
    Hi Mecaso , no need to apologise , this is what this forum is for , if any apology is due it would be from me, for not replying to your question.
    I'm glad you got it working , I thought the trim capacitors C14,15, 16 would have the range to adjust the bias.
    I have thought about it and was going to suggest a reverse polarity on one or more of the heads as the heads I have seen have 3 wires + , - ,GND/shield.
    Only other thing (other fault) I could think of was residual magnetism in the heads metal frame , which would need de-magnetizing like tape recorders do every now and then . Looks like a good bit of history you have there and if Klempt Echolettes could talk what an interesting story we could have !!
  4. #109
    Mar 2015
    33
    Hello, oc disorder.
    Thanks for answer.
    Yes, the trim capacitors C14,15, 16 would have the range to adjust the
    bias, but, the resistance of my heads is only 300 ohms under DC, so, this
    is perhaps the reason why capacitors are not sufficient.
    With my potentiometers, i can adjust bias and my NG51S works
    well,.........at my convenience.
    Thanks again....
  5. #110
    Mar 2015
    33
    Hello
    It's again me.
    To realize myself my tape-loops for my tape echos, you would have a brand
    or a particular type of tape to be recommended to me?
    If the rules of the forum does not allow it, you can maybe inform me in
    private message.
    Thank you....
  6. #111
    Mar 2015
    33
    Hello
    On one of my NG51S, i suppose the previous owner has done a modification of the oscillator transformer.
    Is somebody knowing how many turns of wire are wound on the circuit?
Name:	Klempt Echolette S NG 51 Bias.jpg
    So, L1, how many turns?
    So, L2, how many turns? And, too, what is the position of connect to the erase head?
    (How many turns between the ground and erase head?)
    Many thanks & greetings.....
  7. #112
    Mar 2015
    33
    Quote Originally Posted by Mecaso View Post
    Hello
    Hello
    It's me!
    No body knows the answer at my above question
    Thanks & regards....
  8. #113
    Jul 2006
    Land Down Under
    1,267
    Received: 1/0
    Hello again Mecaso,
    I don't know the answer to your question.. but it should be possible to calculate the inductance with the given capacitance to make the 17kHZ (or what ever it is)oscillation.
    It also occurs to me that some of the early valve/tube tape recorders may have a near enough bias coil (although possibly a different freq) to replace the original.
    That's just an idea ... I guess most of the old mono ones are very hard to find now but I imagine there are a lot more in attics and cellars (basements) in Europe than in Australia.
    Maybe a quick trip to Great Britain too before they shut the door ??????
  9. #114
    Mar 2015
    33
    Quote Originally Posted by oc disorder View Post
    Hello again Mecaso,
    Hello
    Thanks, oc disorder!
    I have a drawing with an ECC82 used in oscillator on a REVOX tape recorder.
    But, the ECC82 is used only in triode, not in push-pull.
  10. #115
    Supporting Member epis's Avatar
    Jan 2007
    Ottawa
    36
    Hi guys, when you're talking about HF bias voltage for recording heads (60 -90 -120volts) do you refer to rms, pk or p-p voltage ?
    Thanks in advance
  11. #116
    Nov 2014
    61
    I have 2 of these that need to be restored.
    Is there someone that specializes in these that I can send them to.
  12. #117
    Mar 2015
    33
    Quote Originally Posted by 12xu View Post
    Hello
    I know one man who is able to repair your tape-echo ECHOLETTE.
    He is a specialist worlwide known.
    His link:
    bobbysreparaturen.de
    His mail address:
    f.staedel @gmx.de
  13. #118
    Oct 2014
    112
    Klemt Echolette Repairers
    Hello
    His link:
    His mail address:
    f.staedel @gmx.de
    Hi Mecaso,
    Where do you live, posting to Bobby say from AUSTRALIA would be rather expensive.
    Cheers and good luck,
    Mike
  14. #119
    Mar 2015
    33
    Hello
Name:	Klemt Echolette S...(cont.) - Mozilla Firefox.jpg
  15. #120
    Mar 2017
    Belgium near Antwerp
    23
    Hi Kazzooman , and Bob Translucid , I have 4 Echolettes the early klemt 51 , on wich I have replaced all heads with Woelke Pro Studiorecorder halftrack heads , the set is working but I have to much noise even without echo or tape running .. so I will have to investigate the rest of the machine to find the noisy parts ... the heads I use work fine , I can adjust for bias to give a maximum on sound and that works satisfactory but next job is finding the noise in the machine , the mechanical parts are replaced , the plastic rollers are replaced by quality steel roller bearings like you find in Revox and Studer recorders , the pinch rollers are replaced by old but very good 8track pinchrollers .. you find them in the good old quality 8track tapes the inside diameter is to big but there is a possibility to pres in a 4 / 8 mm adapter in bronze ( bearings self made) some 8tracks have a plastic pinchwheel , that you can NOT use , but some have a synthetic rubber wheel and that's the one to use ! you can use pinch rollers from normal taperecorders also but still you will have to press out the inside bronze bearingbush and make your own , the old Klemts are running on 4mm axes the later Dynacords run 6mm shafts . so far some experience on these German machines , and yes it's a pain in the ass to get to the electronics . but they WORK HO SO FINE when totally in order .. :-)
    keep posted , Ben
  16. #121
    Mar 2017
    23
    Bobby is agood , but there are other people too that can fix your Echolette .. I do .. :-)) in Belgium , and I can suply you with info , and pics ,and a set of heads and mechanical parts , pinchrollers , intermediate steel rollerbearings like on Studer and Revox recorders , Woelke Pro recorder heads for record and playback , only the eraseheads I do not have , but these are not going bad .
    so keep in touch ;; Ben Click image for larger version.
Name:	bearing 4 en 8 od  mm RS.JPG
    Will try to put up some more images later , Cheers , Ben
  17. #122
    Mar 2017
    23
    just put 10 windings around the coil , measure and compare .. and you will know the ratio .. to your 10 windings :-)) easy job ??
    Cheers , Ben
  18. #123
    Mar 2017
    23
    I just gave you the solution read my postings .. Cheers
  19. #124
    Oct 2014
    112
    Quote Originally Posted by staxmotownjunkie View Post
    Hi, I would like to help but I don't know what your problem is, it doesn't show on this site. Maybe you can give a detailed description of the issues that you are experiencing, along with the exact model of the unit and I will try to assist. Mickey
  20. #125
    Mar 2015
    33
    Quote Originally Posted by Mickey View Post
    Hello
    Roller bearings are not a good solution if they are used before record
    and playback heads.
    It is the reason why Echolette use plastic rollers. You can use one
    roller bearing only before erasing head, that is to say, after record &
    play heads, that is to say between the last play head and the erase
    head.
    I had the problem on a Dynacord S-62a, where a roller bearing added
    noise, because roller bearings are made with magnetic metal.
    And, too, do you are sure that your erase head works correctly and
    erases well the track which is running in front of your record & play
    heads track...?
  21. #126
    Mar 2017
    23
    Ho yes mister knowall ?? are you ?? I have three machines converted on roller bearings and they are running perfect without any unnecessary noise ,nor electric , nor mechanical, maybe you can tell me why is Studer and Revox , studio recorders fitted with roller bearings ??those Swiss perfectionists are maybe a bunch of stupidos?? And yes if you forget to demagnetize them and simply touch them with a magnetic screwdriver it could ad some noise , but most of the noise on recorders comes from bad tape , wornout tape, wrong bias what more ? noise in the amps , noisy transistors , leaking capacitors , magnetized heads from 'specialists ' who can not leave it to touch things with magnetic screwdrivers , same kind of guys that are bumping into speaker dustcaps with their fingers , Mechanical noise comes from dirty shafts , plastic wheels , washers that are touching tape while it revolves anything .. take a stetoscope and listen to the mechanics .. easiest way to find it .
    Listen I am a newbee on this forum because I was looking for some more wisdom here , but I am 69 years old and about 55 years busy with all kinds of tubeamps , recorders and the like , so I am more or less aware of the stuff , but you never can say I know it all .. so I am waiting to learn some new tricks ..maybe .... or I can tell you a few .
    No hard feelings :-)
    I just have for the moment on one of my machines a litle problem that I am trying to locate .. don't worry ,I will find it , I have a litle birds-squeel after half an hour on a tapeloop and funny enough the same loop placed on my other machines is running perfect even for hours .. so I will need some time to find out why this loop is making the squeeling noise just on that machine. I will post you when I find it.
    Cheers man.. I ll read you . :-) SEE REVOX B77 rollerbearing before and after heads and NO NOISE ! this is not a Toy but a Studio recorder
    Last edited by staxmotownjunkie; 03-28-2017 at 11:48 AM. Reason: extra Revox picture
  22. #127
    Mar 2017
    23
    Hi Mickey , not a special problem , just a birds-squeel on one of my machines after 30 minutes about , same tapeloop runs perfect on my other machines , I will find it , don't worry
  23. #128
    Mar 2015
    33
    I have sent my answer to staxmotownjunkie by private message.....
  24. #129
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,085
    Received: 110/1
    Given: 95/4
    Ho yes mister knowall ?? are you ?? ........... those Swiss perfectionists are maybe a bunch of stupidos?? .......... 'specialists ' who can not leave it to touch things with magnetic screwdrivers , same kind of guys that are bumping into speaker dustcaps with their fingers .....
    Hey staxmotownjunkie .... cool it, will you?
    You have something to say, you say it, period, no need to insult other Forum members.
    Cool. Keep it that way.
    Welcome to the Forum.
  25. #130
    Mar 2015
    33
    Thanks to M Fahey.....
  26. #131
    Mar 2017
    23
    Ok sorry guys , bad temper sometimes , but the it can happen .. so problem solved ; found the litle Tweety bird yes my friend ,Mecaso :-)
    it was the Plastic idler .
    .Click image for larger version.
    just have converted the machine like my other Super 65's with a rubber idler on bearings .. FINI litle squeelly tweety bird , FINI ratlenoises .. just sweet running bearings no Mechanical noise no sound tapenoises , and running my own looptapes , I ll give you some pics now to prove my conversions , and yes... this machine runs on a Philips 1/2 track playhead .. and it's just putting out the same quality music echo like the original heads . 12 to 15 mVolts depending frequency 400 Hz or 1000 Hz and slow speed or fast but identical to original Dynacord head .
    My looptapes ? made from Emtec ( Basf) Mastertape and some AGFA low noise tapes.. running perfect with minimal friction noisesClick image for larger version.
    In have another Echolette NG51 that is converted with Pro Studio Woelke 1/2 track heads , fully amazing quality !
    pics from that one next time if anyone is interested .
    Cheers ... Ben
  27. #132
    Oct 2007
    10,085
    Received: 110/1
    Given: 95/4
    Cool
  28. #133
    Mar 2015
    33
    Is somebody able to explain how , in 1960, a NG-51S was sold by
    Dynacord as an ECHOCORD Super.
    (Dynacord bought Echolette only in 1969, not in 1960.)
    Please look at this link:http://www.el-me-se.de/old/pdf_files...OCORDSUPER.pdf
    What was the factory who built all Dynacord & Echolette tape echoes
    in the 50' & 60'?
    I am curious to know that...!!!
    The box of the Echolette NG-51S and the one of the Dynacord
    Echocord super S-62a have the same dimensions.
    The heads are the same, the motor is the same, the loop
    is the same, just some differences between them.
    I am quasi sure that the same factory was building them.
    Who can explain that...????
    Thanks in advance...
  29. #134
    Mar 2017
    23
    https://de.wikipedia.org/wiki/Echolette
    read the Klemt Story ..
    it's about Klemt , Echolette and Dynacord .. also Winston .. Klemt speakers where mostly Isophon top of the range to be compafed with the JBL's 100 dB efficiency ! and very warm sounding ,JBL was more crisp in tone ( D130F) , Echolette build the famous Toneringboxes like Fender did .. later dynacord went to RCF and other cheaper manufactureres .. you can see how the quality of the gear went down .. music power and profits went up for Dynacord .. the old Klemt amps where technically fantastic but APITA to work on . especially the first Echomachines with point to point connections , and the first M40 amps .. later on they build Printed circuits .. Dynacord started Pushing EL34's over 100 watts for a couple at 750 and almost 800 Volts .. HT .. Crazy ! one of the best Amps from Klemt is the BS40 , and if you change the outputtransfo from that BS40 for the OPT from an M40 you have the nicest and most powerfull amp with just two El34's .. I modded these amps with two 6550's .. wow what a dynamic ! and no problems of noise from bad singlecoil pick ups .; Dynacord echos went also the cheaper way .. only one record head and 3 playbacks .. all plastic gear , motor with only one spead instead of the 2 speed 6 pole Papst, this in the Dynacord mixamp Eminent 100A the 100 type was an even cheaper version . compare the chassis with the early versions . and the Dynacord MiniEcho .. one playback head ..
    About amps one of the nicest amps was also the M70 from Echolette let's say a slightly better version of the Golden M40 series and in a stronger Vynil housing. I have no idea who started first with the greeneye EM84 in the Echos , Dynacord had a greeneye in one of their 40 watt amps the frist Eminent
    you can swop the EM84 for an EM800 and that's one straight green line instead of two smaller indicators coming together the EM800 is to find in NOS versions in Germany , and cheaper then EM84's
    Attachment 42953
    You can clearly see the big influence of the Klemt technicians in the first Dynacord amps .. this was the sixties area .. the most beautiful vintage stuff was build then everywhere , end of the 60's beginning 70's we got the printed circuit nightmare troubles, it all started in the radio and television branch , man what a lot of problems we got ! chassis tearing apart , bad solderings sockets getting to hot and burn out .. it was cheap to produce but it was the nightmare for most technicians , before we got the contemporary throw away electronics now ! I am over 50 years in the repairbussiness and if I see what is produced now .. my stomac turns around , I don't even want to open the new boxes anymore ! .. anyway ..
    I own most of the early Klemt Echolette amps from M40 M70 M120 M150 the litle BS30 BS35 the Bs40 and almost all of the speakercabs ET1 Et4 etc.. got a big collection . and I like to play them . if you have a question and I can help , just give a shout .
    Cheers , Ben .. staxmotownjunkie
  30. #135
    Mar 2017
    23
    Ok this is it then ?
    I did this week a full restoration of 5 Echocords swerving around as boatancres ..
    full restoration , means to me :
    replace electrolytic cap 2 x 50 Uf with a 2 x 100 mF that fits in the same place straightforward . 10 Eu /pc
    replace the selenium rectifier with a bridge rectifier 1000 Volts 1 Amp // 0.2 Eu piece
    then remove all DC coupling anodecaps about 6 or 7 .. several sizes replace by polyestercaps 600 Volts not one Eu cost in total
    then commes the shitty part : the heads and mechanical setup
    replace open , and worn out heads , quit a few .. replaced by Woelke professional studiorecorder 2 track monoheads using only one track ( half the tapewidth = easy to adjust , just look for highest freq and max volume on scope , about 12 / 14 kHz will do fine at 10 /15 mV .the heads can be fixed on the original mountingplates from the Dynacord heads , need a skilled hand though and some clockworkscrews , NOS Woelke recorder heads are to find in Europe if you search
    the mechanical setup is easy peezy .. the adjusting of the electronics is another piece of cake . the bias must be set accurately because bias from dynacords is much to high ( around 90 to 100 volts at 60 kHz ) Woelke recording heads are better running between 20 and 30 volts . if you know electronics , then you will know how to correct the bias . the LF signal needs to be a litle bit more then for the Dyna heads .. plenty of possibility in the Echocord
    when your heads are done we start the mechanical job ;
    the best pinchrollers are to find in old 8 track cassettes .. the good quality ones have a synthetic rubber wheel that is still soft and functional , only problem: the inside diameter is wrong at around 7,8 mm .. needs a bronze busch to run on the 4 mm axle of the Dyna .. again clockwork workbench turning the bushes on a litle lathe ( hope the name is correct ) and make the bronze bearings yourself because none are to find that fit correctly. ones the pinch roller is done leaves us with the rest of the ratling plastic wheels , I replace with precision metal bearings same system as you can find in the Revox B77 just different sized , in Europe SKF makes quality bearings that you don't hear running and that are dustprotected , not waterproof!!
    the last wheel before tape passes the erase head is replaced with a rubber roller from a copymachine this to smoothen the tape-loops running .. this setup runs like a jewel ! amplifyer: the tubing is sorted for tested and noise free NOS Us 12AX7Wa tubes
    the erase head is checked and cleaned , those very rarely go wrong
    in the same time a 1/4 inch jack is fitted for instrument input and a different AC inlet , standard Euro 3 connections the ones you can find on all PC's and earth safety wire fitted to chassis
    the green eye EM84 or 87 is replaced by an EM800 that I haveplenty of stock new ,it's a straightforward fit ,same pinning and connections , only difference . the EM800 is a one green line moving up instead of 2 lines coming together
    so that's about last weeks work . just one problem on one of the machines .. A Papst motor 6 pole windings with one open winding I could make the motor running on 5 poles but won't start , so needs a fast start and then switch over to slow .; Im not telling how i DID it because it's a trick that is not correct for healthy repair. It's Ok for me because it is the echocord I am going to use my self . We needed 3 of them because we are playing oldschool 50's and 60 's and some Brian Setzer music .. Shadows , Spotnicks etc .. 2 for use an stage and one in spare incase , ... those over 50 years old boxes are out of warranty now .. I am glad I could make them back like new , in fact even better then new .
    So If anyone has a project he cannot finish and he likes to get rid of it .. give me a shout I am desperately looking for a 2 speed motor , they are the same from Echolette 51 machines as from the Dynacord Super's . they can be used for eachother .
    here some pics of the customizing job ;
  31. #136
    Mar 2017
    23
    Just forgot to say //
    demagnitizing everything , very important !!
    all screwdrivers you are using on tapemachines must be demagnetized .. as the heads , the screws anything to do with magnetic tape .. how I do it ?? simple ..
    a very old Engel Loter soldering iron .. take out the soldering pin and install a coil wound from several copperwire windings ( 1mm wire , thick enough to withstand the current .. not very important how many windings as long as you can feel the demagnetizing job in your screwdriver , that you insert in de coil and activate the current .. then while still actived slowly remove the tool .. you can demagnetize the heads from the recorders with it ..
    find yourself a secondhand soldering iron like these , penny's or for free .. if you find it . and make your own demagnetizing tool for peanuts .
  32. #137
    Junior Member
    May 2018
    4
    Does anyone met 500 Ohm record heads on the NG51?
  33. #138
    Mar 2015
    33
    Quote Originally Posted by Souleyman View Post
    Hello
    Record heads, on NG51 are about 1.000 ohms.
    Of course, it works with 500 ohms, but, the record level is inferior.
    And, i think that pre-magnetizing voltage must be adapted.
    When mesuring your record heads, did you disconect them
    from the circuit......?????
  34. #139
    Junior Member
    May 2018
    4
    Thank you.
    I see on the market not only 1k resistance heads. All of my own are really around 1k-1.2k but some re-builders of Echolette says the often use and a 0.5k heads and they are works the same as the 1k.
    The problem is one of my record head unfortunately dead (inside broken wire) and I need to find the one working. Today I can get only the 0.5k version unfortunately.
    I've measured it as in a soldered state and in disconnected too. The same measures.
  1. Klempt Echolette replacement p/b head
    By oc disorder in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-16-2017, 03:41 PM
  2. Klemt Echolette Grounding Question
    By Kazooman in forum Music Electronics
    Last Post: 03-03-2011, 02:44 PM
  3. Echolette B200
    By QJerry in forum Schematic Requests
    Last Post: 09-16-2010, 05:27 PM
