One inch grommets
  • One inch grommets
    Hi, I have a Mesa Boogie Dual Rect two twelve I am recovering. It has four holes in the top one inch in diameter that are lined with black plastic grommets. They have a flange around the top about one sixteenth wide and are five eighths inches long. The bottom of the hole has a metal plate attached to it with holes in the center through which screws are used to hold the amp in the cab. The grommets are there to line the hole for dress. Anybody know where I can get the grommets?
    Have you contacted Mesa ?
    Here is one from McMaster Carr
    McMaster-Carr
      One thing I'll do in a pinch is to get a larger grommet and cut a sector out of it so it'll be the right size when installed. Do it carefully enough, and someone will have to look closely to spot your handiwork. :wink:
      - Scott
        My local electronics store sells those. Look around.
        Don't believe everything you think. Beware of Rottweiler. Search engines are free.
