1950s Multivox "Premier" Model 71
  • 1950s Multivox "Premier" Model 71
    I'm in need of a schematic for a c.1954 Premier Model 71. Not sure where to track one of these down. Thanks!
    Don't know this one, but in general, the older they are the simpler they tend to be.
    In these cases, I usually get out a pencil and pad and draw my own schematic from the circuit. Imagine at first that it will resemble a Bassman or Deluxe. Start with the tube complement, and go fromthere.
      The best way I can describe the early version of the Model 71 layout is, helter-skelter. Later versions did get a little less complicated. I made some diagrams and notes before I started disconnecting things though. This schematic of the Model 76 is somewhat close to the Model 71 (the Model 71 seems to have evolved from the Model 76): http://www.harpamps.com/premier/Premier76.pdf
