4-conductor hookup wire question
  • 4-conductor hookup wire question
    Im wiring a humbucker with a coil split.(I want the slug side hot in the split) What two wires do I run to the split? I'm using the standard Gibson wiring color code.
    Hookup wire:
    Red- slug start
    Wht- slug end
    grn-screw side finish
    Black-screw start
    According to Duncans website: (Seems wrong)
    Grn and Wht go together into the on/on mini toggle.
    Blk and drain to ground.
    Red to the pot lug.
    Thanks a ton!
    Peace
    Mark
    You want to cancel the slug side?
    If you ground the green and white the slug side will be active
      I want the slug side hot in the split. So is the Duncan wiring diagram right?
      Grn/wht to the middle lug of the on/on with the end lug of the on/on going to the ground?
      Peace
        but according to this:
        Hookup wire:
        Red- slug start
        Wht- slug end
        Black-screw start
        Red to the pot lug.
        the slug side will be hot
          Thanks bro!
          I owe you a beer.
          I already had translated the SD color code to Gibson color code.
          Thanks again
          peace
            http://www.grolsch.com/
              You have great taste my friend.
