Hi all
Recently my ph-3 decided to up and die, it powers up (with battery and with power supply) but when you engage the effect..... nada, zilch, nothing. There is no sign of bad traces or components, the jacks all test out fine. I've had a look all over the interwebs, here and at boossarea and all I can find is problems with other effects.
Whilst the effect is engaged if you turn the amp up pretty high you can just about hear a time based noise which makes me think this is not switching over to the effect path, similar to another problem someone had with a dd-3, but I cant work out which part to short out to turn the effect permanently on (to aid troubleshooting)
also would love to get my hands on a schematic for it
any help as always would be vastly appreciated
