Bobbin Position - affect on output?
  • Bobbin Position - affect on output?
    Hi, I have made a number of humbuckers, but have been experimenting with a new design. All sounds good on it, but it's a bit weak on output.
    Could bobbins not being the same height have an affect on output? What if they aren't aligned top to bottom? - one higher than the other?
    Any other comments or help is appreciated!
    A taller bobbin a should have a brighter tone than a standard height bobbin ,but with the same number of turns as a shorter bobbin ,It will use less wire & can sound thin
      Thank you. What if I have two different height bobbins on a humbucker?
        I've made them that way, but I Shim the shorter one on the bottom so they are level on top.
        My Hybrid Bucker that has one blade and one screw bobbin is that way.
        T
          Here's a picture of that one.
          The Screw bobbin is shorter.
          B_T
            [ATTACH=CONFIG]16186[/ATTACH]
            B_T
            Looks pretty much the same as mine. Mine measures 14.3K across the 2 bobbins. Just cant figure out why this thing is weak...sounds good, just weak.
              Mine is 2 different gauges, and is about 13.5k.
              It is sure not weak by any means.
              Did you use a shim between the magnet and the blade bobbin.
              a regular magnet is not wide enough and you have to make a steel shim.
              If you don't it would probably be weak.
              T
                I you think it's weak .do you have the magnet charged ?
                  T
                  The steel shim!!! ahhh....off to the hardware store....crossing my fingers
                    Glad I could help.
                    It doesn't take much Thickness.
                    Another option is a small piece of soft steel wire, like the old baling wire.
                    Something that fits snug in between the length of the magnet, and one bobbin.
                    On my hybrid I put the magnet against the bobbin with the most wire, and shim the lesser bobbin.
                    Good Luck,
                      Glad I could help.
                      Good Luck,
                      Thanks Big Tee, I'll let you know after i get her installed tonight.
                        That did it!! Thanks again, Big T!
                          We need Sound clips.
                          What Magnets do you like In it.
                          I liked A8, C5, and A2.
                          Not a big A5 Fan.
                          B_T
                            Need more coffee.
                            Misread title as "Bobbin Positron"
                              Originally posted by salvarsan View Post
                              Need more coffee.
                              That sounds more like TOO MUCH coffee, actually.
