Real Unrestored 1950's Vintage Geo. Stevens Winder Porn Inside!
  • Real Unrestored 1950's Vintage Geo. Stevens Winder Porn Inside!
    Look what I found - the photos of my Geo. Stevens winder when I bought it!
    There are actually two winders in these photos - the small one in the back of the lower photo with the big dial counter is a model 20, and originally I was going to CNC that one. This one is one of the very earliest Stevens winders.
    The big one on the board is the one I'm restoring right now. This is a Model 120 electrically driven gang winder set up for winding four coils at once. I am now rebuilding this one to wind four humbucker coils at a time too. Originally this winder was owned by a man in Ohio? who owned Bally Bingo (gambling pinball) machines in the early 1950's, and the winder was used to rebuild the game's solenoids. The owner must have had a lot of machines to justify buying his own coil winder! You can see the original arbor with four solenoid coils still mounted on it in the photos.
    Click on the photos to expand these to full size
Name:	Ken's Stevens 1.JPG
Name:	Ken's Stevens 2.JPG
    The Model 120 as found also has the Model 20's original horizontal tensioner mounted on it to wind one coil. The 120's original four tensioners are in the top of the first photo mounted on the rod and brackets - but they are upside down. Here are closeup photos of the tensioner in the right orientation. These are superfine wire tensioners for up to 44 gauge wire - weird usage on a winder originally set up for 22 gauge coil wire!
Name:	unrestored tensioner1.JPG
Name:	unrestored tensioner2.JPG
    I am restoring the original motor and speed reducing gearbox right now, next I will build a new electrical control panel (the box on the forklift fork at left in the second photo). I think I'm only missing a set of gears, a cam, the gearcase cover, and the 'left hand' cam follower and spring.
    Ken
    www.angeltone.com
    That is disputably cool.
      The thread's title was a joke, and I'm sorry if your feelings were hurt because you were expecting real 'porn'.
      These winders indisputably are cool... if you make pickups. If you don't, you wouldn't understand.
      ken
      www.angeltone.com
        Ken, I'd love to see more photos, especially of how the spool of wire is mounted.
          I am in the middle of mounting the entire winder to an EKG cart I got at an auction, so when it's all done I'll post some new photos.
          ken
          www.angeltone.com
            Any news on this Ken? I'd love to see some more detailed photos of that old GS.
