Im trying to figure out a jcm2000 , DSl 100. When i first fired it up 2 of the EL34's plates started to glow red and the amp started humming real loud. I shut it down and the replaced the 2 tubes. The problem went away .
I played through it real loud for 10 minutes. Works fine . ALL voltages and bias test ok. Screen resistors are fine.
I put the 2 suspect tubes back in. Played loudly for 15 minutes . Amp works perfect --no red plating .
The only thing i notice is the OT hums when in standby mode . When i go to Run mode, the OT hums fairly loud , doesnt seem normal to me. Not out of the speakers , but the trans itself.
When i remove the output tubes, the hum doesnt change from standby to run .
Is this normal for the JCM 2000 trans to be so loud ? I doubt it .
So, what do you think?
