I want to make sure I properly install a post phase inverter master volume on a new 5G9 build Im completing. The circuit features a fixed bias output, and a bias vary tremolo. What would be the recommend PPIMV setup to accomodate this circuit?
PPIMV with fixed bias output and bias vary trem
I would use the Bruce Collins style dual pot isolated by 4 caps. http://www.blueguitar.org/new/schem/...d/pi-m-vol.pdf
Originally posted by Chuck H View PostHere's a slight mod on the typical "Lar Mar" or "KF" PPIMV that works with bias vary trems. This is my modification of someone elses pic. But the difference in wiring should be obvious enough. In the original thread I posted this on it's reported to work just dandy.
I've never done it. I just changed the typical PPIMV for a guy that wanted bias vary trem and also didn't want his bias voltage dependant on the pot wipers. What kind of notable affact would loading the PI outputs cause?"Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostI've never done it. I just changed the typical PPIMV for a guy that wanted bias vary trem and also didn't want his bias voltage dependant on the pot wipers. What kind of notable affact would loading the PI outputs cause?
Well, I must admit that I don't entirely get how to read the charted specs. But I thought that when the tube is setup to make primarily voltage gain that the loading was less critical to linear operation. With the tube operating mostly reletive to it's DC characteristics. Then the plate load becomes the load and the AC is more incidental. There are a lot of circuits that load the post coupling cap output of voltage gain stages without the consequences your predicting. Tone controls and such that simply load the signal at frequency or the volume controls in a 5E3 for example."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostWell, I must admit that I don't entirely get how to read the charted specs. But I thought that when the tube is setup to make primarily voltage gain that the loading was less critical to linear operation. With the tube operating mostly reletive to it's DC characteristics. Then the plate load becomes the load and the AC is more incidental.
Originally posted by EETStudent View PostIn an attempt to steer the thread, does anyone have any experience installing a ppimv after a paraphase inverter?"Take two placebos, works twice as well." Enzo
