roland FC100 midi controller - rewiring, need help!
  • roland FC100 midi controller - rewiring, need help!
    Hi
    I just bought an old roland fc100 midi foot controller off ebay, with the intention of using it control ableton live's midi features. when it arrived, i realised i'd made a small mistake. there was no midi output and no power supply!
    i now realise this is cos the fc100 is used to control the roland GT6 or GT8, and the midi and power supply are replaced by roland's own RRC cable format. so does anyone know how hard/easy it would be to replace the RRC with a standard midi output and a power supply?
    the only thing i can find online about this is here: http://f16.parsimony.net/forum27394/messages/321.htm
    if anyone could help, i haven't done electronics since college, and figured this was the place to come.
    many thanks
    collen
    Roland fc-100
    Sorry I don't have an answer for you. I am in exactly the same position and need to know if you have found any solution yet. Regards, Samagoon
      yes, it can be done! i was assisted every step of the way by a very helpful new zealander. i've attached the doc he sent me, with the pin-outs you need.
      any problems, pm me.
        Solution to riddle of Roland rrc port on fc-100
        Hi, Your pinout attachment is very welcome. I have also discovered in the past few hours thar Roland produced a rrc to MIDI converter box called the RMC-1. I have trawlled the net and found a few images of them in expired eBay items but I will keep tuned so that I can buy one if the pinout rewire causes me any grief.
        Many thanks, samagoon.
          Hi samagoon!
          Did you try this pinout attachment?
          How does it work?
          Does the fc100 send midi cc´s or program changes?
          Thanks for help!
          greetings from austria
          zcopter
            the pinout works, i did it, and i use the modified fc-100 regularly, without any problem.
            i cant remember if the fc-100 sends midi cc´s or program changes because i use a great program called bome's midi translator to translate the midi into whatever resulting output i need (cc, program change, keystroke, other midi notes, or multiple variations of all the above). i use the fc-100 to control ableton live (recording and live), reason and guitar rig all at the same time!
            good luck finding the roland manufactured rrc-to-midi converter (RMC-1), i couldnt find anything but a few references to it on the net, and certainly no actual RMC-1's for sale anywhere! but you really don't need to buy one of those - just rewire what you've got. buy a standard midi socket from an audio/electronics site (or e-bay), use an old power supply - and then its 4 blobs of solder (2 for the power, 2 for the midi) - i was surprised how easy it was!! just be careful taking the original RRC socket off the circuit board.
            any questions - private message me. best of luck.
              here's the pinout for anyone else who needs it, and cant get the word document:
              1___________ RX
              2___________no function
              3___________Vin +10v <<<< To DC power plug
              4___________signal GND <<<< To DC Power Plug
              5___________TX - (midi out) <<<<< to 5 pin MIDI DIN
              6___________TX + (220 ohm pullup) <<<<< to 5 pin MIDI DIN
              pin numbers are for FC-100 end (looking at rear of FC-100)
                Hi Collen I'm using the FC-100 to control the Roland GP8 guitar effect processor. My 30' cable has gone south. I found the bad portion of the cable and spliced. I then ordered male and female mating connectors so that I have two cables that break down for easy storage then quick connect for setup. My question: before i do the smoke test and connect the GP8 to FC i want to make 100% sure I've got the right GND ... that's pin 4 - right?
                  hi gajammer
                  i didntreally understand what you meant, so i emailed the guy who helped me,here is his response. hope it helps!
                  If I've undertood the other fellow's question properly... (let me know if anyone wants clarification)
                  1) His cable 'broke' so he repaired it by adding mating connectors between the broken section. (also makes it easier to store the 30' cable apart into two sections)
                  2) He wants to ensure that the 'repaired' cable is still properly configured (when the two halves are joined via the new/extra connectors) - It's still working as a standard RC Cable (not Midi)
                  Answer! He should connect the two cable sections and use a continuity checker to ensure the corresponding pins have a one-to-one connection. ie. no shorts to any adjacent pins etc., pin 1 on one end should come out to pin1 on the far end of the 30' length etc.
                  Additional Point! IF he has used the same style connectors as is already on the RC cable (6 pin DIN with male pins), AND one section of the split cable resembles a shorter RC cable (6 pin male DIN on each end) - the same 'continuity check' comments should apply to the smaller section/length of cable. (In this case the second length of cable would extend the first/shorter one to form the full 30' length - the extended end would mate to the shorter length via a female 6 pin DIN whilst being terminated by a male 6 pin DIN)
                  Crude depiction of two lengths with first length having male to male 6 pin DIN followed by second length with mating female pin style and terminated with male 6 pin DIN.
                  Male-Male cable section Female-Male cable section
                  When joined, they form a male to male (normal config) RC cable
                  In case there's any confusion, the 'female' style is what's built into the footboard... : )
                    I think I've got something of help...
                    Hello.
                    I have an original FC-100 MKII service manual which has the PC board layouts and the schematic for RMC-1
                    If anyone is interested, I can scan. I've been meaning to mod my FC-100mkII, but have not done it yet.
                    Let me know.
                    S^2
                      RCC Cable for GP8 and FC100
                      Hi, I'm quite interested in building a RCC cable to connect my GP8 to the FCC100 foot controller. Would you have the schematics? A detailed process would be nice since I'm not an eletronics expert. If you show me how I can connect wires at the right place. Thanks a lot.
                      Fabio from Brazil
                      Originally posted by collen View Post
                      hi gajammer
                        Make your own RCC Cable
                        http://www.universal-radio.com/catal...s/dinconn.html
                        part #2701 male 6 pin din (pins like photo of 1828) two of these (buy wherever you like)
                        6 or 7 or 8 stranded wire shielded cable (good quality rubber jacket & you'll only use 6 wires plus shield - shield connects to metal outside ring of DINs)
                        solder wires to each end such that matching pins of each end connect together
                        do a clean job and watch out for shorting wires/strands
                        an old Commodore 64/128 Floppy drive cable seems to work, though it's a bit short....
                          Hi there, I'm new to this forum, I just bought an FC-100 off of ebay to control my MIDI units and the listing was....
                          Roland FOOT CONTROLER FC-100 Midi 11 Pedal EXC
                          I thought it was a MIDI Controller, I had no idea it was for a specific Roland unit, Can this be converted to a MIDI controller?? any help would be welcome as I bought it from the US, had to pay extra customs charge and the seller is not being very helpful
                            hi mark
                            i did pretty much the same as you, bought an fc100 off ebay thinkin it was gonna be midi. but it turns out its not too difficult to rewire it midi rather than rrc. rrc is basically midi and the power lead combined.
                            so you have 2 options:
                            1. take the fc100's casing off, take the rrc connector off the circuit board, and solder in a midi din plug (will cost you pence on ebay) and a power supply socket, (use the pinouts provided in my earlier posts on this topic to know which bits to connect to where), buy a normal variable/multivolt power supply (or just use an old one if you happened to have one lying around like i did), and it will work - the fc100 will draw power from your power supply, and will out midi messages through the midi connector.
                            2. if your fc100 came with the rrc cable, you could look into rewiring the cable to output midi and draw power (again, you'll need to get a power supply). i didnt choose this option cos i didnt get an rrc cable come with the fc100, so i dont know entirely how youd do it. i thiknk someone else has posted how to do this. look at the earlier messages.
                            if you get as far as wiring the fc100 to output midi msgs, you'll then need a bit of software on your computer to sit between the fc100 and whatever it is you want it to control on your computer (live, protools, reason, guitar rig, etc) - for this job i heartily recommend bome's midi translator. this will transform the midi messages from whatever is hard-wired into the fc100 into something your software can actually understand. (it can also change any midi message into a keystroke- eg ctrl-z to undo, or stop playback, or change effect or whatever). as far as im aware you need something like bome's even if you buy one of the 'proper' midi controllers, eg behringer.
                            to reiterate: you havent bought a piece of junk that will never output midi - but you will have to learn a bit if you want to rewire it. if i could do it, i expect most people could - i hadnt picked up a soldering iron since school, which was a long time ago, but i managed to do it. hope that helps.
                              Thanks for your help, Mark
                              bodrum escort
                              holiganbet betturkey
