Fender princeton chorus
  • Fender princeton chorus
    hi all, i have a princeton chorus that has a low hum when i activate the chorus cuircit, has anyone else had this issue? very intrsted to find out...... chorus off,, the amp is fine,,, seems to accentuate the hum when activated! any ideas?
    Don't really care if it happened to someone else, let's just fix it.
    Princeton STereo CHorus, or Princeton CHorus DSP??
    Listen carefully to the speakers, each one has a separate amplifier. With chorus off, I suppose both sound OK. When you turn on the chorus are BOTH speakers humming? Or just one? WHich one?
    Does the chorus work though? Listen again, am I right that the chorus sound really only comes out one of the speakers, while the other speaker remains a dry signal? SO is teh hum coming out the dry side or the chorus side? Assuming the hum is only in the one.
