Does anyone know off-hand what size & length the adjustable set-screw pole pieces are in say a DiMarzio Super Distortion? I'm looking to make something similar to that. Thanks!
Set Screw Adjustable Slug Size?
I have an old bobbin with allen head set screws.
I measured with a metric dial caliper.
Refer to the chart.
http://www.engineersedge.com/hardwar...ead-sizes1.htm
The diameter appears to be the m5x0.8
The length is .587" or 14.92mm.
They will thread right in a slug bobbin with the .187" hole.
The hex wrench size is 2.5mm
**Edit Note
Length, may need to be shortened.
I think this bobbin used a 1/4 inch thick ceramic magnet.
So, measure your bobbin and magnet and adjust accordingly."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
m5x14 mm if your using the thick ceramic magnet,These will be a little too long when using the thinner .125" magnet (you need them 12mm long)
or
#10-32 or #10-24 x9/16" or 1/2"
even I have found some of the 10-32 to be undersized & a little too small
metric screws fit better IMO"UP here in the Canada we shoot things we don't understand"
Originally posted by copperheadroads View Postm5x14 mm if your using the thick ceramic magnet,These will be a little too long when using the thinner .125" magnet (you need them 12mm long)
or
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
