Just picked up an Epiphone Valve Standard... and it needs some help! Has a distinct HUM when MV is about 12:00 (kind of like a loud flourescant bulb), somewhat on the muddy side and the tone controls seem to be a bit limited. I was starting to get some help on the 18Watt forum but it closed down today! Figures... anyways, all I have so far is that when I pull V3 the hum goes away. Does anyone have some BASIC mods to get it to sound better? I'm not looking to turn this thing into the Holy Grail of amps... just trying to see if a few tweeks can make it a keeper. I'm just about ready to pack it up and send it back... any help would be appreciated. I attached the schematic for anyone that's interested in taking a look.
Epiphone Valve Standard - needs help
I had exactly same mistake.
PCB is designed so that it can be assembled with or without DSP. The main mistake is, that signal wires on PCB are too long. I mean wire from preamp to DSP and wire from master volume potentiometer to end amplifier. High impedance signal wires can not be so open and so long. Real PCB wiring is done not 100% by schematic, what you have in attachment. Some components are not in use and some are additional. Please look carefully, what figures are on your master volume potentiometer. In my amplifier it was 1M and that is bad if DSP is in use. If DSP is in use, master volume potentiometer must be about 30-75k and linear. 1M master volume potentiometer can be used, if signal comes directly from preamp to end stage. Wiring must be done by shortest way.
I made some easy modifications: 1) I broke long signal wires (3 or 4 wires if I remember correctly) on PCB from both sides and replaced them with coaxial cables. 2) I replaced 1M master volume potentiometer to 50k potentiometer. 3) I changed place for some components: example C27 must be mounted closely to V3A, not closely to VR6. Because wire from VR6 to C27 is low impedance and after C27 it is high impedance. High impedance wire is antenna for hum and noises.
These investigations and changes took from me about 5 hours. I really wondered Epiphones quality and PCB design. That is really bad. Minimum you must check/change master volume potentiometer and replace C27 closer to VR6.
After these little modifications is my Epiphone Valve Standard now much better. Sorry my bad English and long story …
Hi there,
I just had the same problem and this is how iI fixed it.
Firstly,remove the chassis from the cab.With the chassis on the bench,speaker plugged in and
controls facing away,you should see a piece of metallic tape close to the
master volume pot.Hook an alligator clip onto the main star ground and then
touch the other end to the metallic tape.If this cures your problem,you can
solder a wire to the metallic tape and connect a lug to the other and bolt it
down to the star ground.
I hope this works for you,it certainly did for me.
Cheers
Paddy
star ground
paddy,
Could you describe where the star ground is located? I have the same hum and thought putting a balanced jj 12ax7 in the v3 position would get rid of the hum as it cleared it when I put one in my Hot Rod Deluxe. The hum still exists and I want to try your fix.
Thanks!,
Brett
Epiphone Valve standard
hey all I got one of these in a trade...it was ok better than what I traded for it ....
After playing with it for awhile I decided the gain was a little on the not enough side so i opened her up...while upping the gain and tone structure....makes her a real tone monster...way better...(more on that if you are interested later...)...any way I noticed as I removed the board those little fiber washers they used to isolate traces from the screw head fell off as I removed the board...also there is one of the fiber washers that is just sitting on the stand off with no screw through the board to it...make sure you put this one back....also the sta-kon wire connectors that connect the tranny taps and etc..are soldered to the board and are connected to the traces with thermals if you arent carefull when you remove them ( rock them side to side not forward backwards) they will break the pads they are attached to off the board giving a poor or in a worst case scenario no connection at all this can be fixed but its a pain.
making a real playable amp out of her....
C1 and R8 need to be changed to C1 470 MF 50v (or 35v if you do the next change as well) and R8 around 790 to 820 ohms 1/2 watt
I removed the jumper connecting C1 and R8 to pin 8 and added another 470mf 820ohm combination to drive that side of the plate independantly..this way you can vary either side of the tube as much or little as you want by varying the R C combination....
the last one is only if you want to open up the bass a little (or a lot more)...take out C2 and use anything from a .047 to a .1 mf...really booms it up
be carefull i noticed a few cold original solder joints and the wire lengths were a little excessive but wow an AC30 on stearoids when you mod it sweet...add better tubes and a better speaker...now for under 600 bucks these little babies are strong.
side note...I put some old RCA AX7s and some brittish old 60's 6bQ5/EL84 wow!!!!Do these mods or contact me and I will do it for you
Alex
Martian Technologies
exitmusicmusic@aol.com
http//www.myspace.com/exitmusicmusictoexitby
Originally posted by AlexGold View Posthey all I got one of these in a trade...it was ok better than what I traded for it ....
Alex
i want to ask, is this amp basically an AC15?
i ask because there is an even cheaper by Harley Benton which is a clone of this Valve Standard and im thinking of using that as a basis for building an Orange Tiny Terror clone, seeing as the Tiny Terror is basically an AC15 with an extra gain stage it would work out well.
Hi I have just aquired a Valve Standard Amp and it too is humming loud. I read your post and i have a 1m in the Volume control so i will swap that out as you have done. My question is How do i move C27 closer to Vr6. Just by extending the wiring on the board to relocate it?. Thanks for an imformative post.
Alex,
I saw your 4 year old post and thought I would give it a shot...tried emailing first but got a bounce back. Posting here to see if you or any other members might notice my message.
Anyway, I too picked up an Epi Valve Standard on a trade and I actually traded up like you. The difference though is I skipped out on electrical shop during junior high and hardly know my way around electronics. I can figure out some basic stuff like using a soldering iron, but some of the more techy speak, I'm lost.
I have that same hum everyone has with their Valve Standard. In addition, I don't know if the gain is that weak, but I can hardly tell it works. On top of that, it seems to work in tandem only with the master volume...meaning I get zero volume altogether if I don't turn up the gain at least a little bit. And of course, there is no volume at all if I just use the gain and no master volume. The person I traded with said that it could have a tube going bad because 1 of them (the farthest right if you're looking through the back) is slightly dimmer than the others.
Another thing is the darn speaker. It's so bassy, I turn the bass all the way down. Otherwise, it just kinda drowns out everything. I'm actually surprised this is a 15 watt amp - other than the dang bass, it's not much louder than my 5 watt Fender. Many people say the first upgrade should be the speaker so I found a vintage Jensen P12-Q that I intend on buying for $35 on Craigslist and trying that out.
Anyway, all I'm trying to do is practice through this amp without getting annoyed. Not trying to make it super nice or spend tons of money or put towards a lot of effort. Just want to play it as intended.
I was hoping to get a little bit of guidance from you to an ultra newbie on what I can do to correct my issues. Sounds like shortening wire could possibly eliminate the hum and I think I can figure out undoing a soldier joint, cutting the wire, and re-soldering. But the other things you mentioned are over my head. Would love to get any easy advice you could recommend. I would hate to scrap this amp and go after something else. Seems like there's a lot of promise with this amp if one would have some patience and put forth the effort. Thanks for your response in advance!
