multi tap windings
Originally posted by Austin View PostSo its a switch to reduce the voltage, only on the primary of the power transformer instead of the secondary? The THD Univalve has a switch like that on the secondary.
Originally posted by printer2 View PostThey got a patent for that? Tapped primaries have been around forever.
Musicman was using that circuit in the 70's.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by imaradiostar View PostPatents usually have a disclaimer that you can't patent something that would be obvious to someone knowledgeable in the art. Pretty much any Mesa patent seems like that to me. How do any of them ever get through?
If you're the first to apply a technique to an application (a practical adaptation of a generic principle) then that does hold water for patent acceptance.
Did the Musicman amps specifically identify the line-voltage switch/setting as useful for voltage scaling the operation of the amp down from normal to a 'starved' kind of level, or were they only really designed to allow an amp to cover different line-voltage 'regions', as was the case with most amps from earlier eras.
As I understand it, although heater voltage below -10% is a reliability concern over a tubes life it wouldn't be too significant as a not too often used mode of operation. Also most cathodes still have lots of emission margin to cope with lower heater voltage levels.
Originally posted by trobbins View PostDid the Musicman amps specifically identify the line-voltage switch/setting as useful for voltage scaling the operation of the amp down from normal to a 'starved' kind of level, or were they only really designed to allow an amp to cover different line-voltage 'regions', as was the case with most amps from earlier eras.
The Boogie switched primary version is labelled bold/spongy in the dual rectifier amps, so it's definitely for sound considerations and not line voltage issues.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I quick google around and a look at photos indicate MM's early amps tapped the primary of the power transformer at about 60% - which was the 'HI' setting on the front panel power switch - this gave standard heater levels and full power output. With the power switch at 'LO', all secondary levels were pro-rata down. Later models just reduced HT levels, not heater level, and also included standby. I haven't seen a manual, but perhaps hi/lo didn't identify that the amp could actually be used for an application where the musician wanted bold/spongy ;-)
