fuzz/distortion pedal upgrade HELP
  • fuzz/distortion pedal upgrade HELP
    Hi, I've been using a EHX Big Muff for a while now and i'm looking into getting a new fuzz pedal, wanted something with a much more piercing sound. I'm still keeping the big muff I just wanted something which doesn't choke so much when playing straight chords. I've been looking at the deucetone duel rat but would like some advice/help before purchasing anything.
    cheers
    The basic BMP structure has much about it that can be easily modded to produce a broader array of sounds.
    For example, the Sola Jumbo Tonebedner was nearly identical to a Big Muff but had clipping diodes in only one stage as opposed to the two used in the BMP.
    Different issues of the BMP had different emitter-resistor values to produce different intensities.
    Finally, one of the key elements to the sound of different BMP issues is the values of the tone-control components, which you can find lots of useful information about here: AMZ Lab Notebook & Guitar Effects
